Seeing as rota dogged me i had to get a new set of wheels but i think its worked out for the best.
Work cr kai 18x9.5 +20
Very nice. Love the rims :)
Arx with colour-coded flares is sooo much nicer than the Holden Adventra-esque stock style.
As Alex and Craig have said, Nismo needs to be shiny and proud
Very nice mate. Suprised they don't poke more really. Car must be pretty low, by looking at the rear camber.
Clean up that exhaust mate - its a embarrassment to the rest of us NISMO owners :P
i think you should sell me that exhaust
You seem to know an awful lot about teh gayness today.
Wassup wit dat?
Just noticing a lot more m35 gayness at the moment.
I "still" want my friggen wing so I can loose gayness!
Alloy fan shroud arrived for the radiator.
Doesn't quite fit...
Bolt holes line up
But the tabs are a little way off...
Should only be a 10 minute job to move them, and other than that it fits ok so I'll see if Andrew at AM can modify them when I pick up the car.
Only 12" thermos?
I'm using 2 x 14" thermos on mine. Interested to hear your thoughts on cooling capacity.
Didn't give it much thought mate. All the per made shrouds I looked at had 12" fans so figured that was the way to go, knowing that if the fans are cheap Chinese shit that fails I can replace them with larger ones later.
I imagine they'll be fine. Aren't the stock PM35 fans 12"?
Feels good to be driving the whale again. I got the box in, fitted the mishimoto radiator and filled up the fluids, damn this coolant mod is great. ;)
I took it for a short squirt around the block, the box felt nice and tight again, I still need to fit the new 30 row trans cooler before any track duty. Kewish want me to bypass the line pressure regulator for full line pressure then they say it should be fine at PI. :)
As we used a spare box for the rebuild and stole all the good parts out of my old one, I found out the hard way there are two different dipsticks for the RE5. I had to shorten it by around 30mm and turn up a plate to slide into the gearbox. There must be a slightly different housing for later M35's...
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
