Been running it on united 100 since i've been back, its the same price in Qld as 91 octane is in Tas haha
It's been pulling to the left since i nudged a kerb pretty hard even after a wheel alignment or two
and has a rattle over uneven road that i swore was sway bar links but its still there even (but quieter now) after the new whiteline links
so i took it into Pedders today for a $14 check
rack bushes and caster bushes are soft apparently and thats it
so will go for some adjustable caster bushes and nolathane rack bushes
other than that, the front sway bar is going pretty well, rear bar may be on order soon
found a seller in the us who can do it for around $220 delivered: http://www.ebay.com.au/itm/370691983118?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_6027wt_1055
took the stagea out yesterday damn have i missed driving it, going to retune it to put it on bp ultimate though
Moving from E85 to BP Ultimate - why?
Lots.
Needs more info.
I fixed my coolant leak, and refitted the strut brace. Car is f**king awesome.
Dropped past Autobarn to pick up the rest of what I needed for the radiator install - coolant, distilled water, a drip tray, fan controller, adaptor for the BSP fitting, and a couple of hose clamps.
Headed home and started to fit the fan controller before I realised it was a POS. Cables are retardedly short, and the BSP temp sensor fell apart. Returning tomorrow.
Also pulled the front bar off, and the lights out to fit the LED parkers I've had lying around for ages. Found it was easier to spend 2 minutes pulling the bar off to replace the parkers than spend 20 minutes trying to dick around in the front wheel well. Looks pretty awesome.
where i live there is no e85 its totally outa my way considering we use the car everyday
Good reason, but begs the question why you set it up on E85 in the first place...? I bet you spent too much time talking to Scotty, lol.
There is a United on Princess just near your place apparently, otherwise it's just down the road in Springvale, or Blackburn road... Sounds like excuses to me. lol.
Threw a new pair of rear tyres on mine today; the new turbo definitely sorts out treadwear...
I know your fastidious, but if you haven't had a good alignment lately, might be worth checking one out.
I had a shed load of rear toe in, and it has worn my rears quite significantly compared to the fronts. Swapped them to the fronts to try and get some more milage post alignment.
Lol, by the time I saw how much wear there was on the rears, it wasn't worth rotating them.
I've got a set of SPC toe & caster eccentric bolt kits to go in, but haven't had time to fit them...
Might need to book a slot at the Nismo bro Stagea workshop to get up on the hoist with a die grinder.
Once they're in, I can set toe & camber to somewhere slightly more neutral.
I have a set here too but i'm too scared to wreck the subframe. (even though I have a spare here.) Make Craig take pics like the bi*ch he is.
I did mine with an Ozito replica dremel lying under the car on the floor of my driveway. :O
A hoist is a great idea, let me tell you.
What's your worry?
You're only elongating tue slotted holes that already exist. A man of your skills should be able to sort that.
If you don't like them you can always refit the OEM stuff.
Spoolin - ive got a bit of a bone to pick with you over those RSR springs.. they squeek like f**k and make noises daily and you charged me more for these crappy second hand springs than they even were new from import monster with shipping...
again.. watch out for dodgy f**ks on here.. selling you shit thats simply not worth it.
Did you wrap the top and bottoms with coil tape? This is to stop squeaking springs you know...
great bump mate - it was only nearly 2 years ago.
dude had a financial meltdown and disappeared after selling up agggggeeeeeesssss ago.
LOL WOW, clicked on the link from my content, must've taken me to about page 1 :O
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
