It's only taken you a few years. :P
lol yeah yeah yeah. It's taken me just over a year, but it's been a busy year. Hopefully taking my time and doing it all properly pays dividends.
Adjusted the rear swaybar on the M35 today from the softest to the middle setting... Holy shit what a difference!
Would be keen to go all the way but I'm a bit worried the Mrs would accidentaly get it sideways around a roundabout in the wet & clip a gutter. :(
From memory those settings Alex listed were the Whiteline recommendations? Thats what I've got my car on and it feels great.
Why Cusco Zero2Rs? BC BRs deliver, and are cheaper?
Ordered my internal bits today: pistons, rods, head gasket, studs, pins, rings, head studs... Getting excited: it's all coming together: block is in getting honed and prepped, so will hopefully have it all screwed together next week...
That said, I imagine my tuner will be taking Christmas off, so I doubt I'll even have a run-in tune until mid January at the soonest...
Not what i have done but what i've found out:
you can now use google translate (at least on android) to translate photo's of text from jap to english!!!!
Pointed the phone at my fuse box, highlighted the text i wanted and bam! It told me what the japanese said and it made sense!
yeah, i downloaded it and printed it out
but its also useful for other areas where there is no known translation
or for areas of interest for the jap service manuals (r33/r34 etc)
Car was finally tuned yesterday. Bad day for it with the heat, but oh well.
We had issues with the config of the EVC to start with. For some reason it had started just delivering 7psi. By the end of the day it was fine and back up to 15psi, but it's pretty obvious that I'll need Scotty's upgraded wastegate spring.
Few things still to clean up on the tune but we'll get there.
looks good Ryan.
Seems like the shut if down pretty early- about 6000rpm. Stock turbo is out of puff anyway. Magic question - what was the AFM volts maxed at?
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
