  On 19/12/2012 at 12:25 PM, scotty nm35 said:
The coolant thermostat? It's just three bolts, no need to remove the radiator or fan.
With the o2 issue, I seem to remember Jaycar having a kit to combat this very problem. Perhaps you could look into it?
I'm pulling the radiator out anyway to put the Mishi in, and switching to thermos.
I'll look into the Jaycar kit and see what I can come up with.
I'm seeking some guidance on what i should do to my stagea next. I have a hi flow turbo, and need/want both the dump and the FMIC. I can't afford both just yet, so can anyone recommend which would be more beneficial to go in first.
Cheers
  On 19/12/2012 at 11:08 PM, bigkevracer said:
Dump/exhaust. No question. FMIC looks shiny and nice but didn't notice much difference.
and you wont notice a difference with the FMIC. but when its 40+ degrees, your car wont be as bad as the stock FMIC, and you can also safely run more boost.
No PM yet... I just got back a spare actuator so I can send one over to Perth, that way you don't have the car off the road too long. I will need your original one back though, for the next person. :)
I had a thrash around Sandown today, happy to say the car ran very well. Still have to work on the cooling setup, even those massive 30 row coolers aren't up to the task. I may have to invest in some kind of water spaying setup for the front. 30 degree day at full noise saw everything shoot up. Oil hit 127 degrees, water 122 and the trans got to 105, all within 3 laps. :unsure:
At least the gearbox was ok. No limp mode, no slipping clutches. :)
Thats impressive Scotty. Thermos or clutch fan?
I've seen guys run water sprayers on intercoolers down here and seems to work a treat. Might be worth a go, and sounds like a cheap solution.
I got the Mishimoto radiator in today finally. Not a fun job. Even the new G35 radiator needs a lot of modding to make it fit.
Still need to connect the hoses and fill it up, and sort out the trans cooler. Not a job I'll be doing today, outside, in 39 degree heat.
Twin thermo's and the engine fan, all running constant.
Those Mishimoto radiators are a little difficult to fit, the top right mounting pin is slightly out, meaning you need to ditch the rubber part, and the condenser is hard up against it.
Rear mounted radiator?
Glad you had no failures; you could always drive slower... :whistling:
Edited by Daleo
  On 23/12/2012 at 3:28 AM, PN-Mad said:
Got home to see the wife vacuuming the dog hair out.
Training completed. :P
Well done....I'd believe she is a hard one to crack as well!
I had mine trained in 3 months.....she still don't vacuum though!
In a Christmas miracle, the car is back together, radiator in, Nismo thermostat in, Mishimoto silicon hoses in, B&M trans cooler in, bled (sort of), trans topped up, and ready to go.
That Mishi radiator is a bloody pain to fit. And bleeding these things? Scotty's cooling mod makes it easier but its still a bitch. Seems like the trick is to get the billet tap exactly upright the whole time you're bleeding.
Looking forward to driving for the first bit of tomorrow, and then giving it some hills spanking on the way up to Mannum for holidays!
What nismo thermostat did you fit. Is the one for the vq35 the same?
Yup. VQ35 is the same. Temps average at 77 now. Not sure if that's too cold but we'll see what happens when the thermos go in.
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
    • I actually have an aftermarket hanger, the detschwerks x1 hanger, but my dw420 has never really sat in it correctly, good to know I can just modify it a bit to suit. Yeah cheers man will definitely have a play with it and hope it solves my dramas.
    • Seriously though, it's the Shaft Autoservice high mount rear spoiler: https://az-style.shop/items/5ffaad5a72eb464137a6edb1
