good luck with that its a fun job!!! try and get the O2 sensor off so you can get to the bolt behind it otherwise get a special ball joint cuppler for the socket not the yoke type cos it'll just bind up..........
ive got it booked into my mechanic so ill let him have the fun job. Was getting late so thought ...f#ck it. I see what people are saying. Bout not alot of room in there.
It's all about undoing the 4 bolts for the g'box crossmember & lowering that down to allow the engine to tilt back on the mounts. This gives enough room to get to the O2 sensor & top bolt/s. You may also want to drop off some of the shrouds further down the exhaust. This is why I raise the back of the car as well, otherwise ramps would be all you need. Your mechanic will have it done in no time on a hoist. But tell him to leave the bonnett up when he puts it on the hoist, just in case the engine hits.
Well, after stripping the bits i needed off an s2 at the local wreckers the car went in to have the manual conversion done.
Cant wait to drive it from the workshop to the exhaust place..... much excite
I vented my bonnet yesterday!
Seems to be doing the job......f#$k it lets(pumps) some heat out! When the thermo's come one I get that weird heat haze concentrated in one area. I'll post a pic of the top once I get the edging on.
Oh and purchased all new Nismo decal's! Just need Arec Tune to polish car now! :P
Which bonnet is that Craig? Getting copies made?
Lol, is that what you did?
Because race car.
my mates with evos have the same thing
DO NOT lean on the mesh! or you will end up with char-grilled patterns on your hand, though on evo's the vents are directly above the tubro
^^^ like!
Also like that it means your leg must be at the stage where your confident in driving a manual!
Yeah all progressing nicely, been driving now since July last year. Right knee is holding up, still gots a long ways to go tho. My PT is great as he's had a knee reco himself, so he knows the limitations when training.
Decided now that I got some extra cash and the time to take the car off the road to get some thing happening. Need to get new guages to monitor vitals, also check my ecu as to wether I can send it away for the nistune mod.
Picked up an m35 nm35 pnm35 oil sump pan from Nissan. Sorry just being obvious for the search function.
It's the bottom black thingo, so if you dent it, you can replace with
Part number 11110-AL810
I modified mine for an oil return, so when we took the turbo off, we placed with with a beaten out one until I could get a new one.
List price is $170 plus gst. Maybe a little cheaper.
Apparently lol
E-Troll alert!!!
Dale......yes it pumps the heat out......looks a lot neater with the edging now.
*****Cough*****reminder******cough******front******Reo!
Edited by Jetwreck
E-Troll alert!!!
Lol, fab starts tomorrow. ;)
Why did you put the hole there Craig? Is that really the hottest area? Or you just picked somewhere easy?
I was always hoping to get the Masa bonnet eventually...
http://www.rhdjapan.com/masa-motorsports-m-tune-frp-aero-bonnet-hood-56834
So I finally moved the stepper motor for the boost controller, cut almost half a metre out of the hose to the actuator, which was good. Others are *slightly* longer, so I'll test it tomorrow.
Because the back of my bonnet is already raised to get the air out. Also that is the area that most of the air get stuck in...I was finding the thermos could cool but because our bonnet is so low the air was still getting stuck in the front area. If a sidewinder is ever shot at my car now I know where it's heading. Those masa bonnets are nice but I cannot justify $1k ATM when I have other needs/wAnts.
I thought you proved that raising the rear of the bonnet did more harm than good, or Scott told me you did..
finished venting bonnet today......Wing and Front bar to go!
Great job but not entirely convinced it's in the correct area of the bonnet. I reckon positioned a bit more on the passenger side and higher would have it quite effective with heat extraction from the turbo area.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
