Great job but not entirely convinced it's in the correct area of the bonnet. I reckon positioned a bit more on the passenger side and higher would have it quite effective with heat extraction from the turbo area.
Any venting has to be better then none at all
finished venting bonnet today......Wing and Front bar to go!
Whale can has blowhole?
Lol Jokes, it actually looks pretty good, you've more stones than I have to take cutting tools to your bodywork
My bonnet is stuffed anyway.....and there also might be some vented ones getting made very soon so to me it was a no risk!
I would not have done testing on a good bonnet.
so if i'm correct this will be cleared by custom's and getting sent up this week, if it's not being too hopeful...............!!!!!
** also i dont know if it can be viably made for under $1000 each but i'll get the ball rolling once i get my hands on it **
Edited by WAGON_BOY
nice ;)
Put in the new intercooler today made a diffrence driving around in this crazy heat.
thought it was going to be a prick to install but it went in nce and easy.
HDI Intercooler? Yeah not too hard to do, just need to think about it and lubricate the silicon.
Do want. Carbon or Fibreglass?
Pulled the head off my Stag on the weekend. Did the head gasket. Not sure what happened. It's an RS4(S?) with 103,000km on the odometer, but I think it's been wound back somehow.
Blew the gasket on cylinder 6 into both the oil and water galleries, and it was starting to let go on cylinder 5.
As soon as the temp gauge started to rise, I pulled over and had it towed. Fingers crossed the bearings are fine, as the oil is quite milky.
Planning to have it back together this weekend coming providing parts and head machining aren't delayed!
These arrived at work on Friday for me and I've got myself booked in for this coming Friday to get them fitted
Wrapped in a set of these (They're Falkens, to add some fuel to the Nitto vs Falkens debate :P)
At the same time I'm getting the coilovers fitted AND the bushings kit from the group by. Basically, its christmas.
Oh, and I played the 'jump start your car because the battery is too flat to charge' game on the weekend too.
That must make it Adelaide cruise time! There are a few people keen for a Feb cruise.
I did really exciting things to my car: I retuned the throttle. *YAWN* Feels better though.
Falkens? I read somewhere in a thread that they're pretty good.
Nice wheels btw, :woot:
Finally got an alignment!
Toe was massively out, even on the rear (which wasn't altered at all)
and the place i used actually found more things wrong than when i got the pedders check, so i doubt i'll back there in a hurry
most annoyingly tho, they didn't touch the new adjustable bushes and said there is something wrong with the caster bushes because they aren't stock
good news is that caster is up to about 4.5-5mm and its sitting on 1.5-2° of camber in the front
Will have to give them a call about the superpro bushes and see what they think is wrong
Who did u go to?
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
