rear pads in, hopefully gotten rid of the wear issue i have been having, right hand pins/sliders were seized, so relubed that up and seems to be working better now. could actually slide by hand when i was done.
Got the HDI FMIC on yesterday, not too bad. I need to sort some broken/ missing/ torn out undertray bolts asap. I have the NUR catback exhaust and Scotty's dump and front pipe on it already. I think the next thing is Dales induction tube and a high flow turbo. But which one ? What I want is a quick road car not a race car I can nurse around the street, and the numbers are less important than the feel and driveability. But I'd love to try before I buy. :unsure:
I have the kits that Commsman uses to tweak the computer but haven't had a chance to solder them up. (Before anyone jumps on this I have been working overseas from 2/12/12 till yesterday.) (And I have not had the car tuned yet. :yucky: )
Hi Leigh. Give me a while & I may have a hi-flow you can try. But I wouldn't rush to change the standard turbo out, unless it's had it.
+1 with Leaon about the turbo.
If you do the Banjo mod and keep good oil in your car the stock turbo can perform very well and is hard to beat for off the line drivability.
OK Thanks for the offer Leon and all the great help, assistance and advice you have given me so far. I love my sound system/media system. The cruise is absolutely necessary and even the wheel switches started lighting up since we did the slimline fan in the FMIC install! Go figure! :wacko: As it gets quicker it gets harder to set the cruise to avoid it hunting but that's expected at some level as the turbo spools. Just went down town through a 50 zone and watched the car burble up a rise at 900 rpm/50 kph in top gear! Gotta love that... When I said that I wanted to try before I buy ... I meant experience what other turbos respond like, not necessarily from a drivers seat. A seat of pants from a back seat where I can see the rpm, roadspeed and feel the response should give me a clear idea if it is too laggy for my taste. This car will never be raced, if it does go down a drag strip that will be the exception rather than the rule. The problem is trying to find the balance between driveability and power. As I do not want an extreme car some of the more prominent peoples experience is irrelevant. It is probably true that the people I really want to connect to do not post overly much. So if you are out there and have a moderate highflow and induction solution with great driveability and reasonable performance at a realistic price please respond! My standard turbo is OK atm so I am not under any pressure at this time. :closedeyes:
i'm pretty sure someone is rebuilding the turbo basically to stock spec's might have to ask Jet_Wreck about it.........
hi Andy long time no speak, what's the banjo mod?
That's where you drill out the turbo oil feed line at the banjo bolt. It is a really small hole that can get blocked by grunge, especially if service intervals were 'stretched' when back in the mother land.
It is widely believed that Aaron's turbo failed due to this oil line being blocked.
Looks like he thinks Craig's advice is irrelevant, it's the reason I never posted a response anyway.
cheers Leon. :)
Replaced my broken cibie light glass.
Cleaned up ok Josh?
Looks like he wants something he can drop in without tuning etc, and doesn't want the power some guys are making. I get that.
I don't think Craigs' recent thoughts are common knowledge, ie he wouldn't know if irrelevant or not. And, as it turns out, is very relevant.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
