Well thanks for jet r31 getting me off my butt and giving me a hand, I've nearly finished hooking up my water/meth injection, then it's tune time again see what happens :) cheers brother . Also I fitted up my rear brake conversion and front adjustable camber and radius rod arms and chucked in a set of new tie rod ends and a afr gauge to go with the rest of the info in my cockpit
Ready for the cruise? Or you taking the daily?
Had my drivers side front wheel bearing replaced this morning; nice & quiet again.
Not doing it myself was the best $160 I've spent this week.
God I'm lazy. :woot:
Edited by Daleo
  • Like 1
You are lazy! Easy job is easy!
Just got back from the retune.
Car now runs on the MAP sensor. MUCH MUCH MUCH more responsive, but no more power. Apparently 200kW on a Dyno Dynamics now, but no print out.
The weird thing is it's running Scotty's modded actuator and only running 9psi at the top - so it's 2psi more than last time with the stock actuator.
Got to get this boost sorted, and find out why it seems to be speed limiting still.
Much better package though, and much happier. Just want my farkin boosts!
9psi? it sounds like you have a leak in the vac line, or yours is the only turbo not holding boost.
Did your turbo have a larger wastegate puck or something?
Perhaps the actuator doesn't have enough preload?
Check this. You need about 3mm of the width of the hole on the actuator for preload imo.
Bigkev ,no print out I would be asking "demanding a print out " it's an important reference to your car it's no good having all the bells and whistles and not having a guide to what it's doing and be a grumpy man if I was you
^ This. Just what the hell are they doing Ryan? You'd think for a shop with such a reputable name, they'd be a bit more helpful... or is it because you don't have an R35?
I think he's had someone else look at it..? or run it elsewhere. Dunno who has an AWD Dyno Dynamics unit off the top of my head!
Ryan, check out Theo's boost drop. He's stock turbo too, I suspect it's all about running out of compressor flow.
http://www.skylinesaustralia.com/forums/topic/357886-lambchop-with-a-renault-axis-here/?p=6493662
When I had my stock turbo it would hold at least 13psi to redline. No doubt it does run out of flow, but 9psi sounds too low.
How is boost control being done Ryan?
Thanks guys. I'll try and tick everything off...
I've replaced every vac line now I think. I can't see how that would be it.
Stock turbo, stock wastegate puck. Andrew at AM wants to bore out the wastegate 1mm but nothing has been done yet.
Actuator is your modified one, exactly how you sent it to me. If it needs more preload do I just put a stronger spring on?
Which hole Craig?
Thanks guys. No printout, it was supposed to just be a fix session and the map ended up being redone. I could have asked for the printout. I didn't. I'd just sat in the passenger seat and seen the whole thing so didn't think to ask.
Mine was similar to that (although wtf is that at the end of the drop off?!). I wouldn't have thought it was running out of compressor flow that early? I thought others had more success on the stock turbo. Funny that Theo and I have both changed the vac hoses, and both get similar graphs.
Scotty's modded actuator with the HKS EVC.
9psi is the boost I used to get when my boost solenoid would stick open. Sounds like the wastgate is fully opening.
Weird thing is, it was 7psi without the modded actuator, 9psi with.
I want to see if I can find the boost problem, fix it, then take it to somewhere else to get the EVC setup properly and the tune checked.
For the record, the original tuner (who I won't name on here but some people know) once I explained all the issues offered to fix it, ended up retuning on MAP instead of AFM at my request, and spent near enough to two hours with me explaining things and talking about it. So far it seems like they have fixed it and improved it no end, but at the request of a few people I'll get it checked out just for peace of mind.
My actuator has almost 5mm of preload, the stroke of the thing is huge.
The hole Craig is talking about is the hole in the Wastegate arm, that the pivot pin goes through.
Boring out the Wastegate isn't going to make it hold boost better, if anything; it will allow you to bleed boost pressure more easily.
It would be worth doing if you were building boost pressure uncontrollably, but you have the exact opposite issue.
What's stock? From memory 3mm isn't it? And I didn't think Scotty modified that hole. Should I drill it out to 5mm?
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
