I hear a certain m35 owner has got his hands on a sought after nismo cat back exhaust!
I'm sure his neighbors will appreciate the lack of truck noise when he goes test driving now
Hah hah.....Nismo fitted.
Sounds very different to vq25.
Oh....I have mofo 20psi launch again if I want it....so much so that the brakes could not hold it. It also needs a tune before having a run as its running way too rich.
Second biggest win is the front end rebuild. I have finally fixed the vibration under load.
  • Like 1
What was the problem? I get a vibration in the GTR sometimes under heavy loads in the front. It also happens more when accelerating down a hill.
Pulled the front cover of the vq25 again to find out where this oil leak came from. Turns out when we done the cam chain replacement we cracked the rear cover a bit. So cleaned everthying up. Got some steel knead it and hopefully its done the job. This time we made sure we followed the service manual. Letting all the silicone go off then top up the oil and fingers crossed its fixed tomorrow.
I'm Pretty sure is was my steering rack.
Decided I'd attack this water leak. When we fixed the oil leak, my cousin removed a thermostat housing bolt think it was a front cover bolt. Not realizing where it was from, everything went back together without it. So I put it back in and no more leak. Will take the car for a good long run tomorrow and try sort out this warm start issue.
I just fitted R33GTST front and rear brakes on my WGC34, I am just running the std master RDA rotors and pads it works and feels great. So much better than the factory cast crap brakes.
I recommend this to all stag owners.
taken the M35 for a drive this morning, no oil or water leaks.
But came home turned it off went to start it and it wouldnt do its warm start again, ran a fault check straight away and got these 2 codes.
P1110 Intake Valve Timing Control, LH Bank
P1136 Intake Valve Timing Control Solenoid Valve, RH Bank
​So im guessing that's the VVL front cover on the passengers side?
Any help where the drivers side solenoid valve is?
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
