Finally got to post up some dyno charts. Not earth shattering (308 AWKW) but it feels fast to me. I have had some good days on various tracks but now looking forward to setting a 1/4 mile time. Trouble is Friday nights are drag days and I work at nights but hopefully I will get down there before too long. Progress has been slow - no time or money - but some new plugs and a better setting up of the wastegate and a touch up of the tune should net me a few more AWKW.
RB30 is great for the Stagea (mine is 1800kg with me in it) - pulls away from 1000 rpm in 5th comes on boost 2500 and full boost at 4000 (rev limited at 7000).
  • Like 1
What I don't understand, is why didn't Nissan make the cars with this engine....with their weight they really benefit from a few extra ccs.
Good dyno result, particularly on 98 (it's getting rare over here to see a medium or high power build that is not running e85)
Imagine one with a non turbo rb20! Lol!
Downfall of having capacity based road tax systems. Big cars, silly little engines.
Great result; especially at all four!
It must have torque up the wazoo; sounds like a great thing to drive.
So, 12 months, 2 radiators, 4 turbos, 3crankshafts, 2 sets of pistons rings and bearings, 5 unsuccessful dyno runs many many $$ and a new set of coilovers later, it looks like I may have my car back on the road tomorrow... Fingers crossed!
Pics to follow once I've finally had a chance to get behind the wheel again: cannot wait to post that it runs perfectly and made good power!!
Excitement!
installed boost gauge, car runs 14.5 psi, was hoping it was running a little lower so I could have upped the boost. So i'll just go sort the rest of the exhaust and still aiming for hi 12's
wish I had smaller hands! today I tackled, spark plugs, fuel filter, air filter, cleaned afm, attesa fluid and replaced all the dead lamps in the climate control unit! and refitted the stereo so it sits flush with the climate control :)
couldnt face doing oil change today!
What power is the car making? I ran 12.3 at 270ish RWKW and a slipping clutch. Its all about getting these heavy things off the line.
Put the boost gauge in, only reads .4 bar boost (running 10psi so .7bar) and barely reading a vacuum (maybe -50 mmHg but should be at lease -250)
Anyone ever pulled one apart for repair?
Edited by pipster11
So finally got my bars painted :worship: and refit them to the car,while the bars were off i plasti diped the grill and pulled apart the head lights and plasti diped the inner crome bits [ :domokun: obviously not the reflective bits]oh and also bought a new autech badge for the grill and had to make a bracket for it as it was STOLEN with the badge last time :angry: and cant be boughtscottsstagea006_zps159c8845.jpg
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
