Last night after many hours of F n around managed to get the oil filter off, I don't know how hard the rb25 is but the rb26 is just rediculous, removed the batter and then the fuse box (pushed that forward to where the battery was) after getting that off I was happy to then attempt to change the oil. Also did the gear box oil (maybe had 2.5 litres in it) car shifts alot nicer now. now to do diffs and transfer case next.
wait till you decide to take the starter motor out.......if it's anything like the BNR32 its a BITTTTCCCCCHHH!
Lol I had the same problem when I first got mine.their is an easy way to do it but its tight,all you need is the correct tools and to just undo the fuse box so it moves slightly and you can do it ill post up a photo of the tools tonight when I get home (if I remember)
this is all you should need
1x 10mm socket
1x extension
1x rachet
1x oil filter socket
