What Have You Done To Your Stagea Lately?
Hanso
Two blokes, workin 9-5:30pm doing a full paint correction. APC, foam lanced, ironX, clay bar, polished for 4 hrs with ROs, sealant, wax. Knackered.
Not leaving the garage with it before the stagea cruise!
Who did it Alex?
A workmate of mine.
He does a bit on the side for some cash. Very professional and very OCD. Would recommend. However if it catches the nail, it isn't coming out, so if your thinking those key marks, they could be reduced I guess, but not removed.
He's in the bexley area. Have a look at his handy work on Sunday :)
A workmate of mine.
Nah, I'm not worried about the key marks right now; no amount of buffing will get clear back on the exposed black base. The damaged panels will have to be sprayed which is on the list currently. I hate vandals...
Looking forward to seeing the results mate!
Took my car to barbagello, first time on a proper track to open her up. On the last run got my courage up and pushed it harded and passed a s13 easy and reeled in on a 345hp chaser. Hit speed cut on the back straight :( and got plenty of fade from the brembos !!
Next up is install sld dyno and dyno run..
Very happy with the car atm!!
Took mine got its first proper drive since the build: absolutely fantastic! Only downer was the plague of Lycra lovers, and the rubber messing up my front and rear guards ;) .
Almost crossbreed it with a Toyota 86 today when some complete muppet in a white Toyota 86 decided to speed up and try to turn right from the left lane of the roundabout I was going straight through. Really clever: was within 2 inches of having his car as a bonnet ornament...
very nice suction pipe!
P.S. Without the fan shroud I suggest you do some shielding in front of the pod to get rid of the hot air.....remember the heat sensor is in our AFM and it will affect your power through traffic.
  • Like 1
A1RM's still fade. Better off keeping the HPX for road duty and running some race pads for the track.
I got project mu track pads with the brembos but didnt put them on obviously.
Whats the view on skimming the rotor if i change from the track to street pad and vice versa?
Replaced shocks all round, and bled the callipers since i was there.
Also - HPX are hopeless for track work. I know two people who tried tand both were miserable failures.... A1RMs are a whole different story, but i would expect they would be tough on rotors if you used them for street. Cold bite is not great either, so agree that pads are the #1 thing to swap in and out for track days (or maybe #2 after tyres).
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
    • I can totally get why you like it for that sort of commute. I was thinking BoganDore because it's such a lazy drive, for things like stop start traffic.   I used to do over an hour in stop start shit from one side of Bris to the next, twice a day. My choice of car was larger displacement, with an auto. Basically for torque in low rpm/very low speed, and no clutch pedal. But loved a fun manual for the weekends, which the partner has (plus had the LandCruiser too for other fun drives). I now have an EV as a work car, and I tell ya what, ultimate daily driver, especially if youre out of energy, like I often am after work. I don't even need to touch the brake pedal   That said, I'm presently rebuilding the Liberty GTB to get it setup for weekend drives and track abuse! So small high revving turbo engine with 6 speed cog swapper!   But for your style of commute, I'd probably take the MX5 too!   For those choices, I'm ignoring fuel economy. Because I know how atrocious V8 daily life is for fuel from when I used to daily a manual SS, ha ha. Hence why I know I love the daily rumble of a V8
