What Have You Done To Your Stagea Lately?
Hanso
nice work stageaharts , heaps of tuff C34 stags in adelaide now..be good to all meet up and see how all the different combos go
cheers
darren
Thanks mate, I've had the old girl for a fair while now and it's been a long process but I'm really looking forward to the final product. When it's done a cruise would be a great idea :)
productive day today,
Tinted the front windows, played around with the idea of matching the back tint but as its so dark and would be illegal i decided to keep with legal darkness,
also the colors will never be the same so it will never truly match the privacy glass.
also found and fitted a pearl white Dayz front bar, still needs to be tideyed up but looks allot better imo,
also found allot of the bolts were rusted so replaced the lot.
collage_20131012125308604_zps56136482.jp
next in line is coilovers amongst a long list of other things.
also did not realise that the days front bar uses different foggies?
$1360 later...Finally transferred the rego for the stagea into my name with Victorian plates, now I can start changing some bits n pieces :)
fitted some Hardrace adjustable camber arms so that i have enough adjustment to stand my wheels up and get some decent wear out of a set of tyres, just need to get a proper alignment done now, and to see if i need to invest in the adjustable toe arms as well.
fitted a brand new set of splitfires and a brand new oxi sensor to the fridge today,
i dont think its ran right in the months i have owned it as it has a heasitation and missfire even with new plugs and all frwesh filters so, idles bang on now, keen to take it for a drive home and see how well it pulls,
hoping i get better fuel economy now too.
Checked the timing yesterday properly, plugged an old plug lead between the coil and the plug to put the timing light onto as i was unsure of the reading i was getting from the blue loop at the back
turns out it reads exactly the same
In the process i had to remove the j-pipe
Turns out there was quite a lot of oil residue in there :(
Thoughts? Turbo oil seals (its after the intercooler tho) or blow by?
Pulls Well :D
New Number plates "260RS" sucks as i've only just got them and moving to brisbane, well car is in brisbane least i can have them 4 6 months or so till i change my rego over
Edited by poohkies
Fitted up the Tommy Kaira dash into my Stagea. I need to modify an S2 instrument cluster to suit. That way I can keep my tiptronic and the gear selector indicator. Also, for some reason my phone wont take a pic where the LCD doesn't look like it's not working right. Also think an LED conversion is needed.
  • Like 1
ordered coilovers today yay.
can someone confirm, for a 99 C34 RS4-S manual AWD, is the rear a fork or eylet type strut?
i assume the RS4-S will be specific?
RS4S is definitely fork rear mount
Non Stagea, but managed to build up my 26 for my vl , pain in the arse to get the flex plate on the rear, but that's all sorted, now just have to get an rb30 auto spiget and I can put in, went to the wrong repco and couldn't get across town to the other that had it in stock in time before they shut yesterday, so after all the engine stuff was sorted put new springs, adjustable upper control arms and different 3 inch exhaust for the rear, Just have to change the shocks over.
Edited by poohkies
I understand the fanboi aspect, but you really think the 26 is so much better? Why? Smaller capacity, oil supply issues, pita throttle setup. I would have shoved a neo head on the 30, or just left it two valve.
I have a customer's car about to go on the dyno, VL with built rb30, it should hit 500kw with good response from the Precision 6766. I don't personally think the (non VCT) 26 is an upgrade over the 30. Unless you can shove the HKS Vcam on it...
fanboi aspect, I also understand the hater aspect, the aspect that people don't know what there doing, Just my thoughts, but everything you have written in your above post scares me that your a tuner builder.
good luck with that dyno figure
  • Like 1
Hmmmm everything that scotty has written is fact ,if your scared it should be from the realisation of the fact scotty is correct !!!! I'm not bagging the potential of a well set up 26 at all , I love them! But they are def not the be all and end all of rb's .
Go for gold scotty on 3.0 will be watching with interest , a " similar" set up to what heading for on the c34 ATM.
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
    • I find I am using the MX5 for everything except long overnight cruises with Jackie, or, if picking up the kids to go somewhere, the SS has so much more room inside, and is much more comfortable if your going to be doing Hwy driving for 6-8 hours And the MX5 isn't bad in stop go traffic for a manual transmission car, whilst the clutch kit has been upgraded from stock, it is still light, and also not having a stupidly light flywheel in it helps as well, I've spent alot of time sitting on the M5, M4 and M7 stuck in traffic when plodding around the Greater Sydney Region in it Another benefit is MX5's are not really a car that gets stolen, you can pretty much park it anywhere, and it will still be there when you return
