this is the connector for the atessa bleeding in a c34 (unplug it and it will run the motor continiously )
Looks like we have something similar, found this in the workshop manuals..
With the rough translation from Google being
3. The key switch to ON state without starting the engine.
4. Remove the connector for the driver side Insutoroa of bleeding.
Been cut off by removing the wire connector •, entering into an air bleeding.
The motor drives the pump at the same time, stopping after a few seconds. In this state
Constant pressure causes the actuator transfer
  • Nope 1
will have a look at that this arvo!
Those workshop manuals come in handy. Hopefully the plug taped into the OBD2 loom has the answer. You would never know about it otherwise.
Let me know how you go Craig, I will do mine too.
and me!
Well it does run the pumP....just need to get motivated and bleed it now.
So that's what that does (just tested it). I unplugged mine when chasing to see why my infometer wouldn't work and it threw up a 4WD light. I never unplugged it with the ignition on tho. It looks so aftermarket & not factory at all, unless my connector is different. In the end I had to take a wire from this connector & feed it back into the ODBII plug to allow the infometer to pick up the CAN signal, so mine must have been changed at some stage. Nice find, thanks.
I don't know if m35 is the same as r32/r33/r34. But if it is:
You will not loose xfer case oil if you drop the front driveshaft. There is a seal
The system will always bleed when the motor is running. Once the accumulator is empty the pump will start up.
There is a second bleeder just above the rear driveshaft (in addition to the one at the gearbox). 9 times out of 10 you don't need to use it, perhaps this is the 1 time.
Decided to smash out my fog lights [ stagea s 2 ] a bit of a hard job to break into bits and get out .Looks heaps better
I did this a while ago, thought I got all the pieces out, then after a few weeks of driving I notice some little bits of yellow glass still in there lol
Can you see what happens if you unplug that plug, start the car and then push the brake pedal 5 times? (if Nissan were nice, it should go in to 2WD mode!)
  • Like 1
As soon as you start driving the 4wd light comes on, looks like it works just fine. I dont know if I would trust this method on the dyno unfortunately. If the pressure ever came back on it would be interesting to say the least...
Have you bled yours yet Craig?
if its as easy as that to disable. im rigging up a switch :)
Iain i did it to mine, it doesnt feel to good after abit of driving in 2WD. the car seems to vibrate in park, or idle.
i plugged it back up to see a difference, and it wasnt vibrating after a drive...
I thought the torque feels better in 4wd, cant explain it, but i think i liked 4WD better.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
