What Have You Done To Your Stagea Lately?
Hanso
They do seem to run a little richer on boost than OEM, I suspect they have a slightly different airflow/Voltage curve. Only the modified cars seem to display the rich running, at least it's better than lean mixtures I guess. Did you reset the ecu before fitting it Josh?
The problem is the 'replacement' Nissan AFM's run much the same as these, and only last a short time in comparison, (something gets damaged inside at full noise for some reason.) I have yet to hear of a failure from these aftermarket afm's, and the price is much more reasonable.
Gives you a good reason to tune the car Josh. :P
Yes a good tune is next on the list once I get a ecu. Was thinking wolf 3d(to give us another ecu option) or greddy emanage ultimate(already tried and tested). Found when I was giving it a little using triptonic once I went from say 1st to 2nd gear it kinda stalled/stuttered.
Well, I bought the red S1 off ebay. Price was OK for S1 Dayz with electric leather. Duco is sh#t but does not make it go or stop. Motor was advertised as stuffed, and it is. Compression test was my worst Chrissie present 3,5 & 6 50psi. So out with the motor and it looks like an RB30/25, same as the Sil is the way to go.
So my new year of Deeper in Debt continues. One would think at my age I would know better But then I am a Nissan Man.
Happy SAFE motoring for all for 2014..
Took the HKS pod filter out and put the factory air box back in with a Greddy high flow panel filter. Hopefully it will be a bit cooler than the pod filter and if I was to get pulled over, it isn't a defect.
Have you got a cold air deflector? That is supposed to help also.
Yeah, I have that. Kept all the stock parts just in case. Although it is a PITA carrying this stuff around when you get posted around the country every few years.
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission
Hmmmm looks like your going to need a 4wd sump adapter and oil pick up for that mission And a lot of dosh.LOL
My Nismo son is doing the Sil Rb30/25 so he does the hard yards and I learn from him for a change. I have been looking at a better oil pump system
for my other RS4 Auto. It has an FFP and a pod and it runs a bit too hot and gets the gurgles I have an oil temp gauge and it gets to 120 when pushed up Henri Robert Drive.. I am looking at an oil cooler, but with a remote oil filter and an oil cooler I think I will need a much better oil pumping system. First I will go like Hanso and refit the stock air box and the cold air deflector. Mrs66 will appreciate the lowering of the induction noise.
Hugh have you put a bigger transfluid cooler on the auto RS4? If it is still routed through the bottom of the radiator that should help. I presume you are using a good synthetic oil! I had a remote filter system but gave up on looking for a place to put it so just got a sandwich plate where I can screw the filter on as its not too hard to do under the FFP.
And what have I done to my Stagea lately? Finally fitted the stock rear wing I bought ages ago, got my under mirror rust cut out and will paint shortly. I got tired of buying cheap and nasty wheels for the track and thought why don't I use my lightweight forged TE37s and bought some Direzzas to try. For the street I got a set of 18 x 8in wheels (ex Nissan GT coupe SE) which actually fit ok. I seem to have lost the ability to paste links on here (anyone else or is it my computer?) so pics will have to wait.
Also removed the knock-off Aerocatches which lasted less than 6 months and installed the much superior genuine article.
(BTW was having a number of problems with this site - unable to paste links etc. Just uninstalled IE11 and reverted to IE10 - all seems to be fixed)
"KiwiRS4T" watch out the heads of the bolts on the bonnet pins will rust out with rain, didn't have a problem washing my car but after it rained they left nice rust lines all down my bonnet :(
No worries have already replaced with stainless!
Tried to rationalise that it's just a car and was not worth commiting murder over because my mother-in-law didn't even notice she'd clipped another car with it pulling out of a car park. Nice little dent right on the crease above the driver's front wheel arch and scuffed up paint on the front bumper.
Mother-in-law is now banished to driving only the Commodore battle wagon which, every time it gets damaged, only elicits a "whatevs bro" from me.
You ought to see my two Stags. None of my doing.
    • I'll snap up some photos when I'm back home, in the office today meeting my "in the office" quota. Have 2x Teams calls scheduled in, office culture they reckon.   I've never owned a proper off the shelf sub, I've always made or modified broken ones with Jaycar plate amps and/or car subwoofer drivers. The current (and broken) subwoofer has a proper home driver in it, Dayton driver, thos one https://www.daytonaudio.com/product/118/rss265hf-4-10-reference-hf-subwoofer-4-ohm FS of 25Hz, which is low but not low enough. Yeah, I think they were brought out to the market to compete with SVS. I would love a SVS PB-3000 but they're not cheap, especially after their price hike. From reviews online, it does look like the Tonewinner D6000 would destroy and with good amount of money saved too.
    • yeah, that happens too.  I'm really enjoying 4WDing at the moment, seen a few beautiful spots and want to go explore more of this enormous country.  The 370Z got a clutch LSD in it and a track day, great fun.  Getting the back end sorted out really rejuvenated my enthusiasm for driving it hard, the viscous one is poo especially in such a short and wide chassis.  The VLSD unpredictability was more benign in a long and skinny Skyline.
    • With my pre/power I use a remote trigger cable(3.5mm jack each end). I turn tv on, it turns both on via ARC. Or, just the pre with the remote or its streaming software, turns on both. Not that difficult at all. Obviously,  you would also want to actually update/upgrade over other factors in your life(bills, family, other hobbies, etc)
    • Yeah, nightfall was very "meh". And I'm crap at pvp, so feels like everyone has cheats(it's just my lack of skill). Final shape has been pretty good. New raid and dungeon are pretty good. If you want to give it a go, probably wait until it's on sale. But, as usual, most of it feels very familiar.
    • This morning was Kingswood's Microscopic Wars. It is the album's 10 year anniversary this year and we went to see them play the whole album as a special show a couple of months back. Was pretty spectacular.
