Me too Andy, roll on weekend for the mock up!
Lets see how good my measuring is... Only other issue I can think of, is that the rotor radius may not fit fully inside the caliper.
Apologies to those who get annoyed with conversations, but did the bleeder valves fit your stock brakes Dale?
So I might be able to make some more money fitting it for them?whistling.gif
You know where it is?
I actually bought them for my new calipers (R32GTR), which are M10, so yes, but the stock rears are an M6 so; no.
Nice; thanks for the offer Craig, hadn't thought of that, was just going to check gasket compatibility as I'm going to need one anyway.
Anyone feel like doing a FAST search on the sump gasket part number? VQ35 and VQ25det?
Apologies for on/off/on/off topic chat... I think?cheers.gif
Edited by Daleo
No apologies needed, gents - the chat is all related to mods you're doing or are about to do.
Today I got this in the mail (because I'm a lazy mofo and don't really like getting my hands dirty):
if you hit it, it would come off.
but the sump plug is at an angle and probably wouldnt come down further than the actual sump itself
this is true.
Are we 14mm?
picked up some new NGK iridium LFR7AIX spark plugs, i had bought 6's instead of 7's and they were limiting my power :( all 6 = $82
also bought 3 quarts of Red Line Gear oil for the Diffs apparently grade 5 shock proof, not that i know what it is. 3 quarts = $75
from perfomanceLUB... guys pretty cheap! after seeing my car i think he wants a stagea lol
this is true.
Are we 14mm?
Can i ask why you used iridiums instead of normal copper?
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
