Scotty - you mean Me?
back then I was working, and obviously wasnt worried as cash wasnt a problem....
Hindisght is great, but who knew my health would have gone downhill to the extent that it did.
What I shouldnt have done was sell the stock parts off.
Point of worrying now is Id have to strip it if I got defected, and sell it in parts. Not easy to do when youre not physically capable.
Or you could have left the stock parts there and avoided the defect situation all together. I have seen 430kw on the stock manifolds and 500kw through a stock panel filter with the lid modified. Stealth power is the goal... I just wish I could explain it to more owners before they spend big on race parts for the street.
Welcome to the nanny state syndrome. We have been putting up with it in Vic for years.
  • Like 1
I just did this wire mod, what do you guys think ?
http://www.youtube.com/watch?v=U1sGB5wzTQI&list=UUy8-_O-nFlyB3bc8f3ywJsg&feature=share
Edited by poohkies
  • Like 1
So since installing my coilovers I'm having the same problem as ghost. Wheel and tyre hit the coilover now on compression. The gap is a couple mm different on each side which is weird.
I've raised the back but it still does it on big bumps. will have to figure something out.
all fun and games when you want "fitment"
Quite. Your rims are clearly too wide. You will get the same look with narrower rims with different offset or spacers.
keep driving it, it will self clearance itself after a while...lol
cheers
darren
Did a quick touch up on the tune today, didn't lean on it as my laptop (with the program & tune files) was having connectivity issues with the AEM Fic-8 ecu. Laptop is ancient and kids have kicked it once too often in the car.
Low boost tune @14psi made 247kw. Plenty left in it, but putting up for sale so decided not to push it.
Would have been nice to max it all out, but nevermind.
haha yeah right darren,
18x10+15 with a 265 at -1.2deg camber had those on with the cusco's too till I put the jtc's in
That's weird, I've got 9.5 +12 with 245 45. no camber adjustment in the back. it looks like as the camber increases on compression it hits. So if add some more positive it might fix it.
get a big washer from bunnings and space out the bottom mount or get a longer bolt and use more washers.... if yours is an auto/auto converted to manual ( r33 rwd rear strut )
manual rear cradle so no can do.
troy that looks good, not too sure on the chrome strip though, might work
And thinking about also doing the chrome strip that goes around the car.
I've painted the grill matt black too but wouldn't get rid of the chrome strip as it will make the car look more dumpy if you know what I mean...
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
    • Nah, it's different across different engines and as the years went on. R32 era RB20, and hence also RB26, the TPS SWITCH is the idle command. The variable resistor is only for the TCU, as you say. On R33 era RB25 and onwards (but probably not RB26, as they still used the same basic ECU from the R32 era), the idle command is a voltage output of close to 0.45V from the variable resistor.
    • It's actually one of the worst bits of Nissan nomenclature (also compounded by wiring diagrams when the TCU is incorporated in ECU, or, ECU has a passthru to a standalone TCU).... the gripe ~ they call it the TPS, but with an A/T it's actually a combined unit ...TPS (throttle position switch) + TPS (throttle position sensor).... ..by the looks of it (and considering car is A/T) you have this unit... https://www.amayama.com/en/part/nissan/2262002u11 The connector on the flying lead coming out of the unit, is the TPS (throttle position sensor) ...only the TCU reads this. The connector on the unit body, is the TPS (throttle position switch) ...ECU reads this. It has 3 possible values -- throttle closed (idle control contact), open (both contacts open, ECU controls engine...'run' mode), and WOT (full throttle contact closed, ECU changes mapping). When the throttle is closed (idle control contact), this activates what the patent describes as the 'anti stall system' ~ this has the ECU keep the engine at idling speed, regardless of additional load/variances (alternator load mostly, along with engine temp), and drives the IACV solenoid with PWM signal to adjust the idle air admittance to do this. This is actually a specific ECCS software mode, that only gets utilized when the idle control contact is closed. When you rotate the TPS unit as shown, you're opening the idle control contact, which puts ECCS into 'run' mode (no idle control), which obviously is a non-sequitur without the engine started/running ; if the buzzing is coming from the IACV solenoid, then likely ECCS is freaking out, and trying to raise engine rpm 'any way it can'...so it's likely pulling the valve wide open....this is prolly what's going on there. The signal from the connector on the flying lead coming out of the unit (for the TCU), should be around 0.4volts with the throttle closed (idle position) ~ although this does effect low throttle shift points if set wrong, the primary purpose here is to tell TCU engine is at idle (no throttle demand), and in response lower the A/T line pressure ... this is often described as how much 'creep' you get with shifter in D at idle. The way the TPS unit is setup (physically), ensures the idle control contact closes with a high margin on the TPSensor signal wire, so you can rotate the unit on the adjustment slots, to achieve 0.4v whilst knowing the idle control contact is definitely closed. The IACV solenoid is powered by battery voltage via a fuse, and ground switched (PWM) by the ECU. When I check them, I typically remove the harness plug, feed the solenoid battery voltage and switch it to ground via a 5watt bulb test probe ; thing should click wide open, and idle rpm should increase... ...that said though, if it starts & idles with the TPS unit disconnected, and it still stalls when it gets up to operating temperature, it won't be the IACV because it's unused, which would infer something else is winking out...
