Fitted up a kakimoto R tonight. Thanks #@DaveM35 for the swap. Car sounds awesome.
Glad you like it mate! Thank you as well, I can't believe how quiet mine is now I forgot what a difference the old zorst made!
Nice to meet you Josh, can't wait to see the results after tuning
  • Like 1
Cracked open the metal polish and put in some elbow grease, showed the Nismo some love.
Still my car for another couple weeks so it's gotta be shiny
So shiny, looks awesome mate
After doing an intake pipe for #@Brick, and a false start with a silicone upper reducer bend; I made him a blanking plug for the resonance chamber on the back of the OEM reducer bend.
Figured if I was doing one, I might as well do two... :whistling:
10544996_10152577957682392_1605917192_n.10515032_10152577957997392_1365672219_n.
I honestly don't know if it's the placebo effect at work but the car seemed more aggressive on boost.
Later, Josh rang me to let me know he'd fitted his, and that he was now apparently hitting boost cut; which it hadn't done prior to fitting.
There has been no change in AFM clipping on mine; it still skirts juuuust below the cut point.
Perhaps the reduced turbulence on the back of the bend is improving flow? Not sure.
The thing I did notice after I'd removed the resonance chamber, was that it had 1/4 teaspoon of incredibly fine dust inside; almost like talc.
Would be worth removing & emptying if you still run the chamber on yours.
  • Like 1
I have done this on a few cars, it's nice having a lathe handy hey Dale. :P
I can't say I noticed a performance increase, the chamber is there to help smoothen any pulsation over the AFM hotwire, so it's probably just a voltage spike.
Always handy to have a lathe at your disposal mate, one of the (many) perks of the trade for sure. Even nicer to have some spare time to knock out a couple of simple jobs... :whistling:
Hadn't thought of the voltage spike; I wouldn't have expected the effect to be so pronounced TBH. It didn't change my expected AFM readings at all.
This is unrelated to thread but the exhaust clips got me geed up to post a vid of the TT Gallardo we did at work a couple months back
Stagea guys know cool and this is cool so thought I'd share.
First time linking to a vid and first time I've uploaded to YouTube so hope it works
  • Like 1
We can no longer be friends Dave.
So sad.
Got the Stagea back from the garage last weekend, after my AFM fault was cured. Had an electronic boost controller fitted with an AFR and boost gauge. Pretty pleased with the PLX gauge. Looks nice and very functional. I'll be fitting oil pressure/temp sensors to the gauge at some point too.
I also fit in the amp and sub in the boot but that is only a temp fit, held down in the boot with springs. Need to get a longer ground cable as the one I have is a little short. But I'll sort that when I get around to making a raised boot floor to cover the LPG kit which I plan to get fitted. I figure I'd be raising the boot floor by around 100mm, which then also gives me plenty of scope to build a number of compartments for tools and other bits.
I've finally added a stereo with Bluetooth capability to my car. It's another Alpine unit, but I decided I couldn't justify spending a massive wedge on a single-DIN stereo with touchscreen display if the BT tech was going to be old and unreliable. Alpine hadn't bothered to release anything new for that market in 2 or 3 years, and not many other brands either make something similar or something I like.
I used the opportunity to get some sound deadener put into all the doors too.
Love Bluetooth in the car. CCS did the work?
Thinking about using them for a new alarm; they seem very thorough.
Got the boot struts re-gassed to 1200nm. Why didn't I do this sooner? $96 very well spent if you actually use the boot.
Did you remove & check the ball ends on the body when the struts were out?
About 2 weeks after I had mine regassed I snapped one off.
Very annoying.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
