Is that figure per strut?
That was for the pair
Did you remove & check the ball ends on the body when the struts were out?
About 2 weeks after I had mine regassed I snapped one off.
Very annoying.
I didn't remove them, did look them over and they looked to be in good nick.
The strut guy actually refitted them to ensure they'd have sufficient force to hold the boot & raise it easily. Oddly enough, he'd done a few M35s and said that each of them had different pressure ratings on the struts, not vastly different - always north of 1000nm.
You won't see a potentially damaged one; they snap the threaded shaft about halfway down, leaving 10mm of thread in the car body. It can also scar the paint on the inside of the C pillar and roof edge if you're really unlucky. I was incredibly lucky not to damage the paint when mine broke.
Support the hatch, pop the struts off, and remove the ball ends. Check the threaded shank for cracking; and remove the rubber washers (if fitted).
If they're undamaged, you've only wasted 20 mins. It took me twice that to get the broken piece out of mine.
One of mine snapped and damaged the roof as I closed the rear door. The other side snapped as I undid it to replace the ball.
Ouch! Will check them out over the weekend then, good tip Scotty & Dale! :cheers:
  • Like 1
Fitted a walbro today and gave her a service.
Also booked it in to finally get the adaptronic and tune done. 25th of august can't come soon enough
Did you run the relay and fuse back to the battery mate?
I didn't really proof read my question...just to clarify, I meant are your struts 1200nm per strut?
Love Bluetooth in the car. CCS did the work?
Thinking about using them for a new alarm; they seem very thorough.
Yep, I did go through CCS - they're not far from home for me either, which helps!
i've been really busy with my stagea lately, i changed my rear subframe.
S14 subframe fits in good, got all adjustable arms in the rear now.
changed the rear wheel bearings too. rolled my guards aswell. :happy:
Last couple of weeks installed new upper rear ajustsble control arms, new bushes for rear sway bar , new front sway bar bushes, and a new battery on Thursday, got one of those new green battery's from battery world
Going to tackle cleaning my coils and putting electro paste on them to see if I can resolve my miss around the 5k rpm mark
Edited by poohkies
well fitted the Cusco brake stopper on the 260rs and it really improved the braking response. Definitely best mod and easiest for improving brakes!
Have you done brake lines as we'll? Very interested in doing this
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
