Have you done brake lines as we'll? Very interested in doing this
haven't done the brake line. Tried to look for it locally but could find it unless custom made. But so far changing the fresh brake fluid and cusco brake stopper really helps.
Last couple of weeks installed new upper rear ajustsble control arms, new bushes for rear sway bar , new front sway bar bushes, and a new battery on Thursday, got one of those new green battery's from battery world
Going to tackle cleaning my coils and putting electro paste on them to see if I can resolve my miss around the 5k rpm mark
keep us posted on the electro paste results, as far as i know in bad situations the spark can leak and ground into the head area
Headgasket lifted slightly in two spots so engine is out on the yellow pig. While out I will take advantage and replace a few hoses and bibs and bobs while on a stand.
The good news is that the bores look pristine with minimal carbon build up. Not as pretty as an ethanol run engine but not too bad given the number of kms, number of dyno runs and the abuse by Ms Wolv (just daily driving in Sydney) for all those years. While it is out we will refresh with OEM rings and ACL race bearings.
The head is being pressure tested before a complete head service and we can tighten up the valve clearances a whisker to get rid of the slight intermittent tick that has been there since the poncams were installed.
Picked up the stagea today from the panel shop after getting rear ended a week ago. Very happy with the work they done, plus now I am de-badged
Are there any pin holes under the badges other then the Nissan? Id like to remove the AXIS & Autech bagde if possible.
No there isn't, But there is another issue just as big really. From factory they put the badges on while the pain is still soft. So if you remove the badges with out sanding back and respraying it, you will have raised edges around where the badges used to be.
Really the best way to go is to arrange to be rear ended like Josh has done & have your car debadged when it is being repaired.
When I did mine that way a few years back I was given the badges on a cool template to allow me to stick in exactly the right place should I ever get the urge to rebadge.
BTW Josh, I'm no photographer but the potato you used to take that picture of your car needs its lens cleaned, or a steadier hand or something. :)
  • Like 3
Lol yeah there isnt much light in my carpark. Plus I couldn't be bothered re taking the picture
Written off due to to expensive to repair
Buy it back, and repair; an uneconomic repair write off isn't a statutory write off.
Stupid insurance companies...
Is this the point at which insurance companies become (even more) hypocritical? Surely they couldn't ask much for it at all otherwise they would have spent almost up to the insured value repairing it. I had an offset head-on way back in 1992 (man I sound old now) in a car insured for $8K and the insurers repaired it and gave it back, yet the damage must have been very close to $8K.
IF he wants it back of course.
I had the option of buying my Stagea back for $5k which I declined then watched it sell for under $2k at pickles. Bargain.
Could have fixed it but wanted the PM
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
