Ok sweet what's his number Josh and what's parts is he making you out if interest?
+61 414 879 711 currently he is making me a custom idle control unit for my cable throttle setup
So i've had a chance to drive the M35 for a few days since getting it back from tuning.
My main observations it that i'm already driving a lot heavier footed when i want the car to come on boost due to the lagg but i'm really enjoying it. The car sounds amazing as it hits boost with the increased air flow however i really need to do something about the exhaust. 3 inch stainless with front / dump and Apixi N1 cannon is simply way too loud for me. Not sure what i'll do but a bit of forum trolling will hopefully find an answer.
Overall i'm very happy. Big thanks for those that helped along the way.
All that's left once i sort the exhaust is doing something about the front bumper (this stocky one with the parking aid has to go).
  • Like 1
I find my varex is too loud for me at times as well even with an xforce resonator so im looking at switching to a HKS silent hi power muffler to try and get the system quieter. It will eliminate the lower pressure in cabin sounds. I also find that the exhaust can have different db notes from bearable to unbearable at times.
Had a minor o-ring issue with the access to the fuel tank and the M35 was leaking fuel after a filled the tank up but all is fixed and it's perfect once again.
I got the muffler replaced today with something a little more appropriate sound-wise. Still 3 inch straight through but more factory looking. Much quieter than the Apexi N1 and the drone is much more tolerable :laugh:
  • Like 1
looks good mate! Can I ask where you got those LEDs from?great fit
Just some cob leds off ebay you can get wireless (RF) ones that can chage colour lol. http://www.ebay.com/sch/i.html?_odkw=cob+led&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xcob+led+halos&_nkw=cob+led+halos&_sacat=0
Cool man what diameters did you use
60mm for the park 70mm for the indicator and 165 for the main lights if i was to do it again i would use a yellow/white 2 colour ring for the indicator signal led (has 2 positive wires and one negative) so it it will change colour depending on what cable you put power on, so it would flash yellow with the turn signal. other than that you probs just need a dremel to cut into the the plastic silver surround inside the headlight. headlights come apart just like normal. oven,heat gun or blow torch to warm up the silicone like rubber stuff then pull apart.Also depending on what look you're after you can get different types of leds just make sure its a cob led ring if u want a more solid ring of light!
  • Like 2
fantastic cheers mate ill look into that
    • My plan is to go the pink option. But still add the 4th fitting near the oil cap and just cap it off for now.  That way I can add 2 extra to the sump and have 4 dedicated breathers/drains if I ever remove the sump for any reason.
    • Oh, yeah, look - here's the thing. You always replace the tensioner when you're going in there to replace a belt....under normal circumstances. You want to make sure it is good and safe, and that you don't create a reason to take the front of the bloody motor apart again. But in this case, OP is replacing a belt that has aged out on time, not usage. The belt is a million miles away from aging out on usage. The belt gets a time "limit" merely because it is made of rubber and can degrade naturally. The tensioner? Not so much. I reckon it could last forever on the current usage pattern. So I reckon if the thing is going to continue to get used at the same rate, replacing the tensioner is somewhat gratuitous. Would I replace it if I was doing it on my car right now? Hell yes. Because my car does 10-20 thousand kays a year. So it's all going to be the same thrashedness. Would I YOLO it on OP's car. More than likely.
    • I dunno. I think any one of those from each side to sump is probably enough. Remember - this is about creating a path for gas flow up from the sump to the cam covers. That gas flow then has to leave via the lines to the catch can. There's probably little point in providing 100% more capacity from sump up to covers cf. what you have from there to the catch can. Put in the 3 convenient ones? Any which way that you see fit. That'd be my thoughts.
    • Getting holes drilled into to cam covers and AN10 fitting welded on. My sump has 2x AN10 fittings on it already. These are the options I have come up with that can be done without needing to remove the sump to add more fittings. In all options front of passenger side cover connects to VCT head drain bung (i know this isn't the best spot but my feeling is it must do something). Option 1 (pink). The back of each cam covers gets its own line to sump. Option 2 (blue). The back of each cam covers are linked and share a line to sump. The front of drivers side gets its own line. Option 3 (Black). Drivers side are Tee'd together and share a line to the sump. Passenger side rear gets its one line to the sump.
    • I'd be surprised if Nissan doesn't mention it in the manual as it seems unlikely that a tensioner is going to last 200,000km.
