Just picked up the M35 and first impressions...
Seating height is much better imo which was the main inspiration for the seat swap. I'll get a few pics once the sun comes out.
The aero front bar is also awesome however one of the driving lights needs a new globe :(
Pics please!
Managed to clear my defect today (wheels too wide [cops around here aren't so great]) by painting and fitting these R33 stockies. They look stupid but at least it's cleared.
Also installed new bonnet struts so I can FINALLY work under the bonnet without the risk of skull damage haha.
  • Like 1
Never before in the field of human endeavour has so little been achieved in so much time by just one man.
Today I replaced a 3 inch length of 5/16" hose on my turbo watercooling return line.
It took four farken hours go to woah; I feel like a retard.
I noticed a significant drop in the rad recovery bottle a few days ago, and when I went looking; I found coolant all over the passengers side steering rack boot. Turbo is directly above this area; great!
Looked around, no real signs of failed hoses but coolant stains on the hard line, hmmm...
After removing the hose, it looks like the hose is delaminated internally due to the radiant heat of the exh manifold, and forcing coolant up the reinforcing braiding and out the cut ends of the hose.
Then did a cooling system flush and new coolant.
As per protocol; thanks go to Scotty for the cooling system mod, which make bleeding the cooling system a breeze.
Good job Scotty. ;)
  • Like 3
ok photo time now that it's finally stopped raining near the beach :P
Everyone has seen an aero front bar before so i only took 1 quick photo.
The others are just random pics of the GTR seats.
The car is pretty messy atm but due to the weather i haven't had the chance to give it a decent clean...
  • Like 2
Dude they look so good. What's the comfort level like?
If I had the black interior I would definitely be putting this high on the mod list.
It's taken a bit to get use to comfort wise and i am finding myself fiddling a bit with the seat position but i'll get it right. The biggest improvement is the height... so much better as now the rear view mirror doesnt obstruct you view at all through the front window.
  • Like 1
I didn't but i did take notice when i was carrying them and to be honest i would say the weight was very similar.
The drivers M35 seat may have been ever so slightly heavier but that may have been due to the air bag solenoid + locking set up... I could barely tell the difference.
Noice! Excuse my ignorance but what are the two switches in front of the cup holder. My RX only has the one switch on the console for the attesa.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
