OK so I got my new grill today....sprayed it up and fitted it.
Thoughts!!
In my old age I am starting to LUV black. :rofl: :rofl:
Some gentleman ran into the side of the N/A today. Not too bad, about $1500. We were stopped at a light and the dude just drove into the rear P/S bar.
Thats fairly impressive, you managed to take two photo, minutes apart & from an identical position, with your finger over the lens both times :P
Looks good !
P.S. It's the case on my Iphone4 not my finger's leaving the mark...lol!
Edited by Jetwreck
The new one, probably because its a bit similar to mine :whistling:
ahh damn! glad youre ok mate
i think they need to do annual testing of older drivers from 70 now.
i got taken out by a 74yo lady who said she had a green arrow to turn. except she wasnt at that intersection.
I've been saying that for over a decade. If they can clamp down on p-platers driving turbo cars, how about annual testing for those idiot elderly drivers!
I see elderly people making big traffic blunders all the time. At least twice a year we get them driving the wrong way down the freeway/expressway.
:down:
The conditions today were clear, dry roads, total visibility ... yet he didn't see me :blink: Time to give it up gramps.
Just put a 32gtr blow off valve on the M35. fits nicely, sounds better...
just need to find a radiator hose i can stick in to make it plumb back again..
i dont really know what this is going to achieve however. i was bored and had the car apart in the garage
Bought one: http://www.northshoreprestige.com.au/view.php/used_cars/2001_Nissan_Stagea_250tRS_FOUR_White_5_Speed_Automatic_Wagon/4470190/
Does that count? :P
Plan at the moment is major service first and foremost.
Then need to decide next move. Intake runner spacer, exhaust, coilovers or front mount probably. Still undecided.
Bought one: http://www.northshor..._Wagon/4470190/
Does that count? :P
Yeah, I reckon that counts :thumbsup: .
I love what happens when you click on the link. It says "Sorry an inventory issue has ocurred". Interesting way of saying the car has been sold.
blacked out the headlights today, had to take the left one out to fix the seal as i saw condensation in there other day.. and thought while im at it may as well get the blacking out of the way.. I love the look..
did the oil and filter aswell.. once i put it all back together my engine check light came on.. anyone have any thoughts as of why??
im thinking when i moved the airbox and bumped the A/F meter just the usual amount when moving nothing violent..
it shoudnt be to do with the lights right??
anyways enough work for today i will run diagnostics tomoro.. see what i find..
car runs fine no different at all..
anyway pics
sorry for the bad pics its the iphone 4 in a carpark... never a good combo!!
Nah, won't have anything to do with the lights.
Did you have the car running with the AFM unplugged? Doing so always brings up the CEL.
If so, it will go away after a little while.
    • Half anticipating the next question then: I have two magnets stuck in my oil pan. What should I do?
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
