So I fitted this over the last weekend.
I have looked at this brace a few times and wondered how much impact it would make. But I hadn't known anyone to do it to ask.
Have you done the OX rear bar and daleo front bar? If so did it have a similar change as they do?
Does it do anything?
It looks like it's supposed to attach to the body somewhere, but with the HICAS rack activated; I don't expect that would be a good idea at all.
So we took the car for a spirited driving on a motorway, long winding roads and back roads. All I can say is the handling is much improved overall, especially less twitching at the rear end. I do have the front underbrace and top strutbrace. I guess every little bit helps.
bought a cheap Greddy intelligent informeter touch, the touch screen is broken. ordered new touch screen from aliexpress.com and all sorted now.
Winning!
How cheap was cheap?
around $160-170. I saw some guys here bought new for $500?
I think mine was around $400 or so when I bought it several years ago (with good US exchange rate), so that's a damn good find.
I'm assuming the touchscreen was pretty cheap too?
touchscreen for $10-20 from China. actually i was not aware the touchscreen is dead when i bought it
  • Like 1
Taking a punt and ordering a Starter Motor for a 2003 LHD Infiniti from the US...
It mounts on the drivers side as oppose to the passengers so i am hoping it will work out for the manual conversion. The measurements look ok
Also measurements will be taken to get the tail shaft made up and then hopefully once the starter is on it will be a case of bolting everything back together with the 6sp from the 350z in place.
Clutch pedal still needs to be sorted and i havent even looked at centre console but i am hoping these are fairly straight forward.
Then will start the ECU head aches:p
(it's totally gonna be worth it)
Edited by Beregron
  • Like 2
Practical mods are the best kind, right?
Finally got the roof racks fitted to the stag, after the roof rack superstore stuffing me around for 2 weeks.
Both of the sunroof's still open which is nice, except its super noisy thanks to the racks. Might have to invest in one of those wind deflectors...if they actually work.
Will be fitting an awning to it in the coming weeks to, for the weekends away!
  • Like 2
what model number on the roof racks they look the goods and also them wheelz good stuff
Edited by stripey
    • The R32 suffers from an instrument binnacle that is uncomfortably close to the design of a VN Commodore's. But beyond that, the layout of the rest of everything, and the materials (ie the vinyl coverings on dash, armrest, etc) are acceptable, and the patterns on the fabrics are not as blergh as those in the R33. And R33 seats are....quite unattractive. I know it's only small details there, but I reckon the R33 got worse than the 32. But the big blergh is the overall shape of the dash on the R33. It's just has that whole Maxima/Pulsar sort of look to it. Nothing special at all. Generic Nissan sedan. Whereas, at least the R32 dash/binnacle was different. Less a wide expanse of boringly curved plastic. More a "cockpit" sort of look, even if nowhere near to the degree that the A90 Supras got. R34 seats look good on their own, until you realise that they are indistinguishable from the shape and fabric on 70 other Japanese cars. And the foam bolsters on them suffer even worse than the earlier cars. Other than that I don't really have an opinion the rest of the R34 interior. I took the bits of the R34 I wanted (brakes and engine) and added them to the best external appearance Skyline in the modern era (the 32). So nyerr!
    • Can I be your first customer? I would like hard lines done for the fuel system, 8AN up and 8AN back and the underside wire wheeled and coated (brush or sprayed) with that black tar shit.
    • Speak for yourself, I love the R33 interior. 32 is blergh. I like the 34 interior too. Then you start getting much newer in most cars and they all turn back to blergh. 馃槢
    • 500-600hp into a RB is already 'sinking endless amounts of money' into an engine. Especially a 30 year old engine. Unfortunately this is the RB Game. Considering stock power (or at least stock components) will do ~360whp on 98 by simply turning up the boost on the stock gear on a RB26, that would be where I'd say the cutoff point for "sinking endless amounts of money into the engine" Cause to even do this reliably you'd probably need to replace all the bits anyway cause they're old, starting your sinking journey anyway. I reckon the least painful way is rebuilding the engine to make 50hp over stock lol. The 'plan your ownership around a rebuild' was a common saying 15 years ago.
    • Well, the NA RB25 is nothing special in terms of the amount of power it makes stock, nor with any easy mods like extractors & exhaust, opening up the intake tract, etc, etc. And just like any small capacity NA engine, getting lots of power out of them takes a fair bit of money and, depending on how far you go with big cams and high compression and so on, quite grumpy to drive. So, boost is the answer. Many many many of them have had a turbo added. This is easy enough. Same as for any engine. Need the things you need to bolt on the turbo of choice, fuel system and management upgrades, clutch, stronger gearbox ( you do not want to run a boost RB25 through the NA box), diff, brakes, etc, etc, same as you would for most other NA+T things. Some much smaller number have had a supercharger added instead. These are good and cool, but have nowhere near the potential of the turbo route. All the same required upgrades apply. So, potential? Anywhere from not much to quite a lot, depending on how much effort and expense you want to go to. Is there value in the effort and expense? Objectively, no, there is not. If you're gaining enjoyment and don't mind blowing a lot of money on the project, then that's where the value is. Parts? Nissan dealers for some. Many many on-line vendors who do Japanese manufacturer spares (buy buying them from disposals at dealers around the world, direct from manufacturers, increasingly from Chinese knockoffs, etc) and warehousing them in Dubai or similar places. Amayama, Partsouk, etc etc. There are quite a few. Some local to Australia, some local to Europe, some local to the US. You can upgrade literally everything. For an NA, unless you're going to boost it, there's little point going past a nice exhaust, as I said above. After that (well, actually probably even before that) you should concentrate on making it handle the best it can, good brake components, light wheels and tyres, and just make it something to enjoy throwing through the curves. You'll never, ever win any drag races, so it needs to be taken as a nice point-to-point car. Throw in some Recaros or Brides, nice Momo wheel and gearknob, so it's pleasant to be in (because god knows, the inside of an R33 is not a pretty place!!) and away you go.
