Not really worth the cost with other options out there but each to their own.
Yes, If money is your concern then this build really isn't for you.
Went for a decent drive then down the freeway around a few open roads. lots of change of speeds from 60 to 110+... very happy with how this has turned out.
Edited by Beregron
Money is always going to come into play with any conversion/modification.
But the way that i see it is that we are all on the hunt for more power or performance, if we weren't then we would leave it stock. I'm happy for someone to correct me, but by doing this conversion, replacing the auto transmission to a manual, and going RWD, you will end up with less power loss through the transmission and in theory you will be getting better wheel KW than before without touching the motor. Especially down low when you are cruising around town where the majority of the power is used day to day.
Yes it may be expensive, but I have seen people spending huge amount of dollars for small power gains.
Edited by DrLui
Some people have half of that value tied up in just a turbo changeover...
It's all relative.
Good on you Beau; go your own way mate, I bet it's going to be awesome.
  • Like 4
Good stuff Beau, thanks to you and your mech for the read! :thumbsup:
Yeah no dramas at all.
If this can help people then that's what it's all about. I know i'm going to enjoy it :)
These kind of write ups are needed more. Most places dont like doing this to have the work come to them. They dont realise that even though they have written up, owners are still going to go to them knowing that owners will get what they want. Unlike a tuning shop in qld that hides all from potential customers.
  • Like 2
Thank you Beau for sharing our link :) We are hoping our guide/parts list will help the next person/workshop wanting to do this conversion.
We did the write up as it was occasionally frustrating throughout the build having very little information. We wanted to keep Beau's bill to a minimum and not buy a large amount of trial parts that couldn't be used. This is why it took longer than a normal manual conversion as we needed to look into every part first.
Yes, this conversion isn't the cheapest one out there however it is something Beau wanted to spend his hard earned money on :) The labour cost of this conversion was the cheapest part of the job. The parts were the biggest cost factor. Which is another reason we decided to give out a parts list, so those wanting to tackle the conversion can start a parts corner in their garage!
Note: the parts we used/suggest may not be the only options, with more research/trial fits there might be other models that will also work.
We have to say a thank you to Beau as without him doing this conversion, we wouldn't have a list to share :)
  • Like 10
Today i got the following done
- took 350z seats out and gave them a good scrub.
- As the passenger side seat pressure sensor is hardwired on m35s, i installed a airbag plug for easy removal next time i have to remove the seats.
- Installed the brake cut mod at the auto gear lever so when in park it closes the pressure switch.
- I picked up a front drivers door to replace mine from someone running into it a while ago. Just needs a respray as the paint is not the best but atleast its straight
- I also sourced the orange interior panels and centre console to go with my 350z seats and to upgrade to the aircon vents being in the rear of the centre console for rear passengers. (You will see in the pic i got a rear boot roof panel not hacked to bits)
Tomorrow i will be installing the drivers door and replacing the top steering column cover due to old boost gauge install.
Edited by joshm35
  • Like 1
    • Both windows operate normally while the engine is running but start to sag as soon as I switch off.  Does anyone know of reasonably priced replacements or other brands that will fit?
    • Actually PowerFC is probably the easiest to get basic data from, it comes with a hand controller and display so you don't need to remember to pack a laptop every time you drive. It also has a PC based viewing/logging option if required. Nissan used consult on these because back in the mid 80s, ODB was just a glint in a standard's body's eyes.  They switched to OBD shape around 2000 (my 2001 Cima had OBD shaped but not OBD compliant port) With the standard ECU there is a cable and software available to give basic data too, I think it is called Nissan Data Scan or s
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
