glad I don't have them in there rear of mine it shits me enough with just the fronts when people walk past at intersections. In Sydney f**ks pull up behind you so close I'd be murdering people all day if I had rear ones lol [emoji380][emoji380]
Aren't rears normally disabled when moving forwards? Unless they're being used for blindspot avoidance I guess.
I'd rather a camera...
I guess but you would think the front ones would be disabled when reversing then but that's not the case! Well not in mine any ways..... Yeah I love my rear camera over beepers any day!
  • Like 1
Finally got around to doing the brake cut mod yesterday. Confirmed with my greddy informeter. Throttle 35% factory and much higher with switch off. I did notice WOT was only 78% does that sound right??
78% is normal. You can scale it so it reads 100%, but I can't remember how.
  • Like 1
Installled new head unit. Working well and much better sound.
What connector is that? it was connected in the old head unit
Yes steering wheel control plug . Previous owner of my stag had it all working to a degree i replaced headunit and have since lost all controls
  • Like 1
bolt on Dolphin intake pipe from JP
:rolleyes::rolleyes:
Problem with this kit is it replaces the pipe that already flows well. The gains are from replacing the lower pipe.
I think it actually flows worse than the stock one. :P
  • Like 1
Steering wheel controls would have needed to be connected separate to the main loom (3wires) and head deck needs to be compatible with resistance based controls. After all is wired you need to teach the head deck what the controls do
  • Like 1
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
