so last weekend I installed a new radiator that Scotty got in for me.
Oem sizing except the core is at least twice as thick I'd say. Didn't require are cutting and went in super easy.
Also got a new oem thermostat, old one was believed to be faulty.
Also did the coolant bypass mod.
I wish I had of done that as soon as I got the car!
Took no time to bleed and the car sits a fair bit cooler.
Now I've definitely got some confidence to make is go a bit better!
Edited by Bmx537
  • Like 3
Sounds good, what radiator did you go with? Any pics or links?
I think I'll have to do coolant bypass mod soon, will read up on the process first, pretty sure there's DIY on here somewhere....
http://www.sau.com.au/forums/topic/410876-m35-coolant-bypass-kit/
Did an oil and filter change and fitted NGK Iridium LFR7AIX plugs.
Played around with the MCA blue heights and damper settings (to get 100mm clearance from exhaust and front crossmember).
Also drilled 30mm access holes to adjust damper settings from the top.
Started modding the cargo barrier by cutting out the lower section.
And just a random pic of a nice clean Crown wagon I saw at a swap meet a couple of weeks ago.
So mca didnt have the bamper setting adjuster uner the shock knowing its a sealed top?.
Bit silly imo too.
Seriously, the only reason the BC's aren't 'as good' is that the rear spring is too short by an inch to sit at stock height in the kit they send. The springs are only worth $50, for BC's or MCA.
I love the MCA's in the evo, but until Josh explains to me why he designed them to be coilovers and how he strengthened the chassis to take the weight I can't recommend them. Nissan ran them separated like that for a reason...
Yeah, and the shock mount isn't designed to take the entire weight of the car; just the shock.
I'm not convinced at all.
Besides; changing the design isn't a quantum leap forward in handling or anything; it's just focuses a lot of unnecessary stress on a tiny area of the chassis.
Bit silly imo too.
Nothing is strengthened. I thought BC were a coilover rear too? The only thing I didn't like about my MCAs is that I've maxed out the spring adjustment and it was still very low so now I've had to use the lower mount to increase height. I was concerned about using a coilover instead of having them separate but I guess I'll have to see how it goes.
Tear a hole, or punch a hole straight though the car to allow for internal adjustment, when the shock mount collapses...
These cars are wagons, hence the wagon rear suspension, and many of them are used and loaded like wagons.. Is it really worth the risk? Would they also technically need an engineers cert given that the type of suspension is being changed to non OEM?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
