Nothing earth shattering unfortunately;
Back to full soft on the BC BR front dampers after stepping up to the stiffest setting on the front sway bar. Got rid of the slightly darty response on some uneven surfaces. No real loss of turn in response, but much less "busy" on rough stuff, and I can always stiffen it up in seconds anyway.
Replaced the two bumper rubbers on my fuel filler flap P/N; 78837-AG000. The original ones were flat as a tack, and as a result the fuel flap never sat flush with the rear quarter; always a bit sunken.:down: Just a small detail, but it's been shitting me for ages.
Dropped a couple of Nutserts into the front bumper support to replace the holes I tapped to fit the mount for my trans cooler. Nothing wrong with them, but the Nutsert will be much more resistant to stripping out due to vibration than the holes into the soft alloy. Another thing that's been bugging me for a while.
Other than that; I also picked a length of 50x50x5mm 316 stainless angle to start manufacturing Heavy Duty rear sway bar upper mounts!:banana: More on that soon.
Edited by Daleo
Im interested to see pics of the HKS 350z turbo setup, most of the intercooler and piping wont fit by the looks of it but it comes with a fair bit of gear. At least you will have known results and great quality, the 3037 is a perfect size imo. What are your plans for the gearbox?
Engine out job for sure to fit the manifolds. Hopefully you can confirm they are stock VQ25det items.
I have taken inspiration from this kit for my adapter to fit the GTX3071 and external gate, hopefully I can jig it up and sell for anyone else wanting to upgrade to a Garrett as HKS aren't making any more kits and parts aren't available anymore. For mine you would just need the Tial housing (as it will make it much easier to fit and have better wastegate flow.)
Yeah, the piping might be a headache. It has been made to work on a V35 auto, so I'm not trail blazing. Basically 3 areas of concern (for me)- the outlet from the turbo fouling the LHS Driveshaft, piping to and from the cooler, and I think the Exhaust comes in on the same diagonal as a Z33, which means I might have to add a little/take a little to make it sit right.
I'll get some photos of the relevant spots for you Scotty asap. Don't expect the kit to be fitted overnight... I pretty much bought it because it was being discontinued and I couldn't not buy it at that price :whistling:
Gearbox will get a service/flush, and a cooler. We'll see how that holds up, It will be running really minimal boost, as per HKS recommendations, cause I don't want a rod out the block... As for building it up, well, i'll let the wallet recover first!
But If anyone finds one of those 4.2 stroker GTM motorsport FI sets that they want to give me...:ninja:
i also need to do this so interested in the part number.
my Air con stinks and I have a feeling this may be apart of the reason lol
Get the one carbon one that filters out ozone. http://www.skylinesaustralia.com/forums/topic/129786-air-con-filter/page__pid__5429174__st__60#entry5429174
I thought the great big hole in the sky was letting all the ozone out, but apparently there's still some down here & it's not good to breathe :unsure:
  • Like 1
Get the one carbon one that filters out ozone. http://www.skylinesa...60#entry5429174
Thanks mate appreciate it!!
Easy job replacing the cabin filter? Did you buy a cabin filter from Ebay?
Yeah the Cabin filter i got was one of the ebay ones, Charcoal Carbon Filters US$24.83 shipped to OZ
http://cgi.ebay.com/...RK%3AMEWAX%3AIT
Where's the Second fuse box????? I know of the one behind the battery, I know of the one down near the accelerator pedal. Where's the other?
In my head the Fuse boxes are"
1, Driver Footwell Kick Panel
2. The Rectangle Box in front off the battery (Maybe more of a Relay box but theres fuses in there)
3. The box behind the battery on the firewall under the wiper trim, this is the one i didn't reliaze was there (which is probaly considered the main one)
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
