josh how much did they charge you for labour on all the bushing mate? Looking at getting all mine done to. Did you run with OEM ones or superpro or the like? Will feel amazing to drive now mate I bet.
I'll send you a message via Facebook regarding price mate.
But yeah all super pro or whiteline depending on the bushes. It does feel amazing. Just need coilovers now and it will have full handling upgrades.
  • Like 2
Taking her in tomorrow for full fluid change, since the car didn't come with service records gonna go ahead and change oil, tranny fluid, diff fluid, and brake fluid
Wondering if anyone might have some insight to a small electrical issue, every so often there seems to be a small power surge causing all the lights to dim. There is a clicking sound when it happens which sounds like a capacitor discharging
Check the simple things first, battery terminals were my undoing last Thursday night in the Stagea when my car would crank over but not start. Was after midnight and the car was in a fairly safe spot, so I got a lift home and tackled it the next day.
Installed a Transgo kit in my M35 today.
Bit of a messy job but found a good tutorial and took my time and got it done.
See how this goes with the paddle shifters.
can you post a link to the tutorial mate?
Here you go.
Not Stagea but same gearbox.
Mine was same at the 5 ball channel casting and also used the white springs where this guy didn't.
Everything else was the same.
http://www.titantalk.com/forums/titan-faq-how-area/107187-transgo-shift-kit-install-how.html
  • Like 1
Sounds like the ATTESA relay clicking, the pump draws a fair amount of current which can draw the voltage down if the battery is weak. How often is it happening? You might want to look at replacing the pressure accumulator if its happening a lot.
I went and replaced the tiny battery that came with my car with an optima coiled cell AGM battery. No voltage dips now, though the relay still clicks a bit.
Ive been thinking of the shit kit , this however looks a lot more involved than when I shimmed my old Soarer's trans.
Nice to see another red one. :thumbsup:
Now do first a big service, and then starts to build.
exhaust system, intercooler, suspension and more
and, of course, look for Axis body kit :thumbsup:
- Key light has started flashing on the dash, which a quick search tells me is a dying remote battery. Life = over.
- Just bought a full exhaust from a 370Z with 55,000km on it for a massive outlay of $50. I know most of it won't fit without...massaging...but it's a heck of a lot cheaper than $400+ for just a replacement Y-pipe and I have a tame welder I can employ. Now I just have to get it all down to Hawkes Bay from Auckland and convince my wife that it's really only prudent to replace the rear half of the system too.
- Ended up replacing the tyres with some Michelin Primacy 3STs of the same size (215/55 R17). Man they kick seven shades of Shinola out of the old Dunlop Enasaves. So grip, much tyre, wow.
- About to head out on another 600km road trip, weighed down by the everything, including a 7-foot ladder and interior door inside the cabin. I have a page-long list of items to take and I'm confident I can make it all fit, the car hasn't let me down yet.
So, all maintenance stuff really but a change is as good as a rest.
Edited by Hertz Donut
  • Like 1
Flushed the trans over the weekend, ohhh back to smooth shifts.
Installed a trans cooler, managed to pop a pin hole in one of the pipes! :O , brazed and all good.
Flushed attesa pump , and then managed to strip/round the filler plug on the transfer case >_< , whoever done it up last time is an asshat. Gonna hunt a new one down Saturday.
Ordered hub rings for the new wheels , got a slight vibration under load from the rear, hope they sort it out.
Edited by malialipali
nice when the next day when you bought your car must use a tow trucks
maf broken :angry:
new now was not an expensive 99€ = 149AUD
always put a spare maf in glove box, that's the bible for M35 user
Edited by YangLIU
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
