Yeah i feel the black head lining is a little too much. Would be different if i had black piller panels etc.
The upholstery and new liner will be done professionally. Not sure on cost for seats but got quoted 180 for the roof installed so thats a pretty good price. Essentially the interior will be black and beige/tan with burnt orange seats and silver highlights (door handle trims and gear stick surround).
The outside i am planning on doing a matt dark blue wrap with matt or gloss black wheels. Ill try and find a picture of the wrap for reference.
After putting up with a low idle for a week , yesterday took out throttle body to wash out with carb cleaner, gave it a good clean - hooray problem sorted.
Went for a good long drive last night to give it a good squirt, blew the passenger globe ! WTF its 6 months old.
Picked up a HID kid at 11, dismembered the front end and took the lights out. All complete by 13:30
While putting it all back together there is a whiff of coolant found that rad is weeping just near the cap :rant: . so now new rad time as soon as I order and it arrives.
  • Like 2
Fitted up a fire extinguisher today. Curse you Mighty Car Mods and your evil sidekick, Supercrap Auto!
Nice removable factory bracket on the non electric passenger seat so the extinguisher moves with the seat.
post-135423-0-20101400-1461413170_thumb.jpgpost-135423-0-00231200-1461413181_thumb.jpgpost-135423-0-39788000-1461413193_thumb.jpgpost-135423-0-74149800-1461413206_thumb.jpgpost-135423-0-36357900-1461413219_thumb.jpg
Yeah that's where they always split.
Think it happens to everyone eventually!
bought and fit headlight, it is 2nd one but near new, cant imagine it is over 10 ages old but still near new, compare with my old set.
now my world is clear again.
Edited by YangLIU
new part arrived yesterday :yes:
yet to do in the near future
exhaust modification
dump pipe
intercooler
intake
bc racing suspension
and new wheels
made as soon as the financial situation to give up :angry:
No big deal Josh.
You can get the 29mm recirc adapter and adapter plate from Nengun.
I used a Subaru adapter plate and just reamed the holes to realign them.
Just counter sink the plate and use counter sunk adapter bolts and take a nick off the side to clear the throttle body.
That's it.
It's well worth the install.
The valve travels so well, the intake recircs like it should.
No shudder, black smoke, dumping fuel.
Really smooth.
The Greddy is 40mm , Turbosmart 22mm, plus the Greddy FV is so adjustable with the two springs plus the wind in plunger.
By far the best thing I've done to this car so far.
  • Like 2
No big deal Josh.
That's it.
Really smooth.
I had a custom pipe welded up for $60, bought a couple of vac nipples to screw in and used a universal turbosmart kompact which had a 32mm base, easy peasy and asthetically good looking
Yes but to pay over 300 for one that doesn't bolt straight on against 189 for a turbosmart that does.....
adapter was easy to make an 8 mm aluminum sheet. but requires a little drilling, and grinding
the time it takes about an hour and the price of the adapter will be 2 €
Picked up a new driver seat today, happened upon it while checking out one of the local Up Garage locations...set me back a whole 20 usd
anyone happen to know the stock rail bolt size, I'm guessing 12mm but wanted to double check before I order a wrench, may just go ahead and pick up a ratchet set thoughHkC5bgbl.jpg
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
    • I am being real ocd and do not want to make amy mistakes so appreciate all help provided. I am overly cautious so asking for opinion even if i know the answer   few questions,   1.re tensioner, should spring be greased lightly?    2.tensioner has two washers , one pressure washer and other has recessed/ seat. I am going to put the recessed one facing tensioner where edges are cut out and pressure washer on top   3. my car has custom triger kit sold few years ago by guy who initially built the engine. I moved the crank gear and it moved in and out easy, only way to remove belt is to slide the crankshaft gear forward which I did. I have seen these being very tough to move , anything to do with my woodruff key?   it has a crank sensor shown in purple which I assume reads from the 12 teeth position mounted to the crankcase gear   4. timing belt doesn’t have arrow stating front or back just a arrow which I think is direction of rotation . Do you agree?   5.i figured out why my crankcase cover was worn as there was no washer installed over the crankcase cover before the harmonic balancer was put in place. It is missing, anyone knows the part number? It looks like this https://justjap.com/products/genuine-nissan-crankshaft-timing-gear-rear-plate-washer-nissan-s13-ca18-a31-r32-rb20-r33-r34-c33-c34-c35-rb25?currency=USD   https://tinypic.host/image/IMG-4535.382Zy2 https://tinypic.host/image/IMG-4537.382dSz https://tinypic.host/image/IMG-4534.382q4U
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
