Scotty says he has a tiny bit of rubbing on full lock.
Plus had to roll the rear guards.
19 x 10 + 30 all round
You might need the Axis ride height for 20's
Edited by conan7772
Yeah i read that somewhere. Do you know what size spacers.
As the others have said, 15 or 20mm.
I run 10mm on my Nismos which are 19x9.5 +40 and have no rubbing.
I don't think I could get away with 5mm spacers, nor would I try for that matter as there is not much room in there.
So I finally get around to doing a few things today.
Replacing a burnt out globe in the cluster, its only the shifter position but it pisses me off at night.
Replacing the weeping radiator. Just ordered one from Natrad $260 inc!!! Bursons wanted $465 (for the same thing). Pickup at 1pm and then the fun begins.
Edited by malialipali
  • Like 1
fan clutch has a little bit free spin, but there is no overheat problem atm. i know most people would say don't change it if no overheat problem, but i want to keep engine more cool!
so ordered new fan clutch (Shimahide branded from JP). now i could feel very noticeable strong wind under bonnet
for someone who has overheat problem, try to change the fan clutch. even though you test the stock worn viscous fan in cold and it is tight enough with just little bit free spin angle. it may have huge difference if you change new fan clutch.
made in JP
good quality
no need to take out the fan shroud, just lose 4 bolts on fan pulley and make some angles to take viscous fan out.
thinner than stock one
new pads arrived, ready for daily fun.
Edited by YangLIU
made in JP
Hook a brother up with the fan clutch ..... link?
Cheers
woohoo , got it all done.
The cluster globe was not burnt out , someone had been in that cluster before :glare: , the track on the PCB was worn away / cracked in one spot, soldered that and tested on bench all working.
Biggest issue was re-calibrating the needles as I had to strip the PCB out.
Radiator was a bit of a pain, but all done, the old top tank started to come apart in my hands, I'm genuinely surprised it had not gone bang.
One more burp tomorrow morning and a bay wash, hope nothing else breaks for a few months, I need to get started on the mods.
Got the Stag back on the road today. Hit a skippy on Easter Monday. It's sat in a forlorn state since. Picked up a complete roller and today it donated its face. Need to massage out the rad support behind the left hand headlight, but it's passable for now.
  • Like 1
May was a big month for the ARX – finally had the head unit replaced with a single din Pioneer and Kanatechs fascia. For the benefit of Canberra Stagea owners, BDL did the install. Then a gearbox flush and off to Scotty’s Customs for a dump pipe, front pipe, cooling mod, new plugs, rocker cover gasket replacement and attessa, transfer case and diffs fluid change. Well worth the trip.
Got the following completed today ready for wheels tomorrow
- changed oil and filter
- replaced front inner passenger guard (grill due to transmission cooler in fro t of it to let heat excape)
- cleaned engine bay
- put the lower stone guards back under the front of the car
- finished securing Axis kit
- painted R34gtt front calipers black (yet to do silver 'NISSAN' writing
- placed spacer on exhaust so it clears kit70fba96b223414a91bfb5704af408dfb.jpge7176bddd3f9a300371b941f1c27eded.jpgdfb4aa956456a135d743585ef51abea3.jpg96f12d9fe38c063b4231f25877508790.jpg2a6161fa8529800f6a2d8ed588807374.jpg
  • Like 2
yeah, my kakimoto also fight with rear bumper. exhaust shop just heat the rear muffler pipe then make a bit angle to avoid the bumper.
Edited by YangLIU
Mine is sold about to go to its new owner so wont be touching it.
Ok so front brakes come up a treat
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
