what do you think of the exhaust ?
I fitted silencers in mine..
Well ive had this exhaust in the past so personally, and the opinion of most, is that it is the best m35 stagea exhaust on the market with the kakimoto a close 2nd. (Worst is the Apex-i N1 as it as loud as farq).
2 days ago i found a leak that appeared to be coolant under the car and assumed it was the cooling mod leaking (this would have involved me removing the intake to get to in down in the engine). Upon inspection it was the oil cooler line had a hole in it so was a easy fix. I just got a generic hose from supercheap and made fit.
Also installed my old braided brake lines i got back from brick (josh). So good to finally get rid of the spongey pedel feel. Once again for the 5th time now cooling system is bled. edd8b54425267c3818e66959879a89fd.jpgdaf6c1938c1e2d93921ddd33cd1954d6.jpg64807028b3ff2824b8a913ff7bd355f2.jpg7c3c5267a9063c9a83c5920634b826b3.jpg32166982a456b5c39f0713cb659bb298.jpg
Looks lovely and clean (love the foamer), do you also bucket wash after the foamer?
However....
6 hours ago, TukeH said:
engine oil (castrol magnatec 5w-40) change
... this (upon risk of opening a can of worms), this made me sad :(
  • Like 1
However....
Always hand wash after foam and two bucket technic
Now I did not understand. I have always used this oil in all cars. once tried my ex bmw liqui moly because I got a cheap :D
where the hell do you find all this stuff Josh..
I've searched and searched and rhd is the only result for the other rear member, nothing in Yahoo Japan
that one looks like it would do more than the other brace too, looking at the mounting.
do you wanna sell it to me..
you don't need two rear chassis braces :)
Edited by conan7772
mistake
RHD is your best bet, i've used them a number of times and couldn't fault them
$320 Deliveverd to your door
http://www.rhdjapan.com/ox-motor-sports-rear-member-support-bar-set-m35-stagea.html
I got mine for $170 to my door. Was brand new never installed.
  • Like 1
you don't need two rear chassis braces [emoji4]
I just keep out a keen eye for bits and pieces that pop up and are lucky enough to get them before newer stagea owners know what they are looking at [emoji6]
You may have your chance sometime next year to get your hands in these bits from me plus many more.....
  • Like 1
I take it you bought yours off stevennnree? [emoji3]
Correct. I was lucky as i had someone interested who beat me to it but he passed luckely. But i saw it on Facebook not on here as my SAU app plays up.
  • Like 1
Yeah $320 is a bit rich for a single brace..
I'm trying to tame my addiction for further mods
  • Like 1
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
