Last weekend, my mate installed the BC BR coilovers on my ARX. Using out of the box height and dampening settings (for now).  Pulled out the Nismo springs which I'll put up for sale later on.
  • Like 1
Put her in for a safety certificate as she is currently being sold. (Sad couple of weeks ahead). Also need to replace roof lining and install the Greddy Profec B II i have sitting in garage for new owner.
Put on another rear wing.
The silver one was a bit short for my liking.
This one came 1350mm long which I cut down on my drop saw to 1220mm.
Gonna spray my mirrors black too.
Now I can carry sheet material on my roof :happy:
  • Like 1
no mate, they're off ebay
just relocated the mounts to suit the hatch, bolted through into the drain void.
filled and touched up the holes in the wing, underneath and so close to the roof you can't see them
mounted with sikaflexed rubber pads
Edited by conan7772
more info
  • 1 month later...
Replaced Greddy IGN chip with another one and hey it works, no CEL.
Had Jez replace my rocker gaskets, and while it was apart replaced my injectors.
I had 570cc "Denso Australia" reman injectors, and had terrible starts and poor fuel consumption. 360km to a tank./ 6km per litre.
These also had leak down.
Bought used R35 injectors and what a difference !
Car starts perfectly, economy way way better, 9km per litre, and my exhaust is 10db quieter.
I've been mucking around with silencers trying to get it under 100db with minimal restriction.
These shit injectors, give such bad atomization, hence why I was high risk of DET, causing loud exhaust tone.
Also don't have rough idle anymore, and that rasp in the rev range is almost gone completely.
Thanks Matt for the info.
  • Like 3
wow, no CEL anymore!
Hmm where the hell do I start...
So I found these three split hoses, one of which seems to have been taped up at some point on both ends because they had splits,
And the other one that goes into the cam cover broke clean out... but that also looks like it had some sealant stuff holding it in there (not sure if that's how it came from the factory)
So the whole mission was just to get to the spark plugs and coils.. who the heck made this process so long.
Here's a photo of where the hose broke out of, looks like it kinda just slotted in there without any thing holding it in?
I finally got to the coils and spark plugs, the coils looked fine and the spark plugs as I've been told looks like they are well used. So I think I'll go and buy some new spark plugs tomorrow because why not lol.
After all that I still don't really know why I'm getting that rough idle/misfire.
I'll get those hoses replaced and new spark plugs, and if that doesn't clean up this problem then I suppose coils will be next. But then again I might even just buy coils to be safe.
And just a photo with the "import" monster drink haha
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
