2 hours ago, NicPM35 said:
Here's a quick vid of my previously mentioned exhaust. Couldn't make too much noise because I cbf driving miles away from suburbia
Holy that sounds mint!
  • Like 1
Sound deadening in spare wheel well, makes big difference to resonance on the highway, more of the stuff coming to put in the door skins and rear quarters very soon, then the big banana will be cosy quiet
On 03/12/2017 at 10:40 PM, Long and low said:
Where did you get your sound deadening? Cost? I'll hopefully get a vid up of my exhaust this week
Got it on Wish, took a few weeks to get here but bucketload cheaper....
One sheet big enough to replace the bonnet card and wheel well was $36 delivered, its 10mm thick and compresses to 6mm.
I'll try finding the link to seller and Chuck it up on here for interested parties.
Edited by oxford1327
  • 3 weeks later...
Just picked up these Rohana RC10 wheels. 20x9 and 20x10 with about 43 offset I think.
Ended up needing 5mm spacers on the front because the offset wasn't quite right, so chasing up some longer studs now I think. Not much thread left with the spacer and the wheel.
Both ends sit out of the guards about 3mm, so should look perfect when I get some lower spings. (anyone got spare lowered springs??)
I could sort a deal out with Springs if your in nz? I'm going to put in adjustables in the new year
19x9.5 +22  -cobra lows
  • Like 1
1 hour ago, Long and low said:
Good improvement.  I couldn't bring myself to sell my Autech rims. They are just sitting in the garage "in case"
Spot the Easter egg....
Chopped? :P
  • Like 1
9 hours ago, m35stagea said:
Got the shits with stock afm and instability in the nm25 so trialing the z33 r35 unit.
So do you have to (can you) retune the ECU to suit?
Are you saying the Z33 is the same AFM as the R35?
And will the same unit work on the VQ35DE?
Installed the RS-R lowered springs from eBay, plus some new 20x8 Vertini rims which fit properly without dodgy spacers. I won't admit how much time it took me to swap the front springs, but in my defence I had about 1ft on either side of my garage to work with.
Pretty happy with the outcome!
  • Like 7
So last weekend I did the lower arm bushes , radius rod bushes, sway bar bushes,  lower ball joints and the AFM . My press groaned on some of the bushes. Those things are in there very very tight. The ball joints are a prick!
Ride improved but it also highlighted just how bad my shocks/springs are. Midday today picked up a set of nearly new Tein GT Wagons and a R33 boot brace to make up a front under body brace.
Fitted the fronts gonna do the rears tomorrow morning, got late for the rattle gun to be going. Took it for a quick spin around the block , holly crap the difference is incredible.
My IT monkey hands are hurting and im cut up but it passes the shoe test.
  • Like 2
Rear springs and shocks done, front underbody brace bolted up. Its now a totally different car. Why did I not do this sooner :huh:??. Drivers rear shock was completely buggered. Could squeeze it down between  my hands and it took upwards of 3 min for it to extend.
I set my heights on the bench. Will let it settle for a week and then set again. Just need to buy some C spanners , anyone know where I can buy some in Perth?
Of course all this effort has brought my attention to another clunk. Passenger side tie rod has play. So now need to find a set before I go get new shoes and an alignment.
Suspension sorted now set my sights for go mods:)
  • Like 3
I'm long overdue posting an update.. don't even remember what the last thing I posted was lol
Anyway, some stuffs has happened, most important one is that my car no longer pings... Took it to E&H Motors out in Pukekohe and they found that the timing was off, which is what I had suspected. A fair chunk of money later i'm happy that the car is now 100% better.
On a cooler note, I bought a LSD diff which I was gonna chuck into a 4WD stag casing but I derped and forgot about the ABS stub axles.. so now I need to try and find some 3x2 LSD ABS stub axles that I can use... otherwise I might try find some 5x1LSD ABS stub axles and put them in it, but that involves buying the axles as well...
IMG_0518.thumb.JPG.47145efa2bcb69db02e993f1c1860fab.JPGIMG_0517.thumb.JPG.8ad87bed83f34ddb4bbf91a4b2b8cf00.JPG
Also got given a spare casing, but I can't use that anyway.
You can see the ABS ring on the stub axle that I need, apparently the open diff one that I have is too short to be used in the LSD unfortuantly.
Also changed out my coolant and changed spark plugs/coil packs to brand new ones.
Other than that nothing cool has happened haha
  • Like 1
Just pressed in a new bearing for the AC idler pulley. Statewide sold me a 6301zz for 5 bucks cause they had em on shelf but not in the POS. :3_grin:. No more howling AC huzzah!
Looking good! So what offsets work on the 8 in rims? Different front and rear?
  • Like 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
