To overcome some current boost issues and in anticipation of things to come I fitted an Eboost2 HP. Works well it’s only a stock turbo so 10psi is it. It works well. It also has the dual shift light on it
45893015_2201894890051722_8361689472860946432_n.thumb.jpg.c5746e4eb0e3943d6b8f5c3613fc4f78.jpgInstalled some BC coilovers on the weekend, and finally got round to fitting the rear 350z brembos.
FYI 350z uses different rear brake lines to Stageas. Bought a set of steel braided lines for a 350z brembo setup, the fronts fit fine but the rears use a different connector to what the stagea has.
45 minutes ago, Long and low said:
That's good to know about the break lines.
How mong did it take you to install the bc's? I have a set for sale but I'm always tempted to just put them in
Rears were a breeze. Fronts took a bit of persuasion with a jack and some other tools
  • Thanks 1
4 hours ago, Hertz Donut said:
Bought it a Honda S2000 garage-mate to make it feel fat and slobby and unloved. VTEC has allegedly been engaged, all of you.
Pics!!
Nothing handy, but imagine a slightly portly, balding, middle-aged bloke saying "oof!" as he attempts to wedge himself behind the non-adjustable steering wheel of a small, red roadster. That's meeeeeeee!
PS: All the rpms work. I checked. A few times.
Edited by Hertz Donut
  • 3 weeks later...
Spend the day fiddling with the rear BC coilovers.
This is as low as I can get them without the shock almost being maxed out.
Took out one of the locking rings and even the lower rubber mount. (dodgy yes I know)
But any lower and the spring will literally fall out going over a bump.
Anyone else have trouble getting real low on the rear with BC coilovers?
The front seems to slam easy no problem
I've been gone a loooong time. Old stagea blew a fitting at the back on the firewall and lost all my coolant.. temp gauge never moved and ultimately killed my engine. Spent a couple months without a stagea and really missed it.. so here I am again, just picked up this RS-v on the weekend, 25DET manual rwd. Sunroof too. Extremely happy
  • Like 3
34 minutes ago, KiwiRS4T said:
Very nice. Wheels look ok too! Got a budget for mods or have you spent all your money buying the car and have to save up?
Cheers, no budget for mods yet. Just want to enjoy it for a bit first, quite a bit different to the old slow 25de 4wd stag I had beforehand. I just need to change the BOV to a recirc one as the car idles quite rough at the moment. Otherwise its pretty mint
This is with standard shocks and cobra lows. I have bc gold to go in. I'll be pissed if they are no better.
Are you referring to the BC BR kit? Because that what I'm using.
Maybe return them before installing if you want to go any lower than mine?
Although I'm not sure if it'll be the same story, assuming yours is AWD rear anyway and uses coil on shock rear?
Edited by NicPM35
Installed Audi R8 coilpack conversion kit from 5-0 ignite, had to do some intake mods for clearances, otherwise would need to have changed to front face plenum and costs/other mods weren't desirable at this point
  • Like 1
Do you have a tuneable ecu or were no adjustments necessary?
Got nistune in it, but didn't need to change anything for it to start and run fine so far.
Once it goes back to dyno will alter the dwell time as per recommended by        5-0ignite that make the kit.
Thus far car runs and idles smoother, as well as no longer seems to stutter under high throttle load, whether that's the old noggin playing tricks remains to be seen once dyno sheet is compared etc.
On 12/12/2018 at 8:27 PM, Akshunhiro said:
I've got MCA coilovers in mine and they go nice and low in the rear. Josh did a true coilover setup rather than separate strut and spring setup from stock.
Does that mean the rear weight of the car is now on the 2 small bolts holding the original shock in place? Assuming the spring is no longer in it's perch
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
