lol why you hating Dale?
its already an ARX, doesnt need to cop more flack! where is the love :iluvff:
No hate mate, it totally changes the look, but when you make moustache references, it just just reminds me of this;
The gay bit: that car looks like a gay swiss guy I used to work with...
'Cept his name was Bruno.
Edited by Daleo
well i got up late this morning, and was already late for work so thought f**k it, im gonna fit this grill
looks good, im kind of happy i didnt colour match as now it works well with the ARX gaynus styled moustache :ph34r:
tell me what you think?
Like the headlights!
Edited by Jetwreck
syn-x 3000 is in, sounds nice
will drive it soon but i think it should be good, just letting the oil drain down from the head to check the level
$40 all up for a oil/filter change is pretty good i reckon
Something arrived today....
My car has a Turbo in it Brah!:P
Hey Alex, that looks like the easiest turbo install ever. Step 1) Place cardboard boxes in rear of wagon. Step 2) Done
Can't wait for the extended version. Good luck.
:blink:
I knew Scotty's been whining about nothing!:nyaanyaa:
That install looks like a piece of piss!
It does seem to have compromised passenger space a little... Silky Terrier now? LOL!
Edited by Daleo
You're right. All I ever hear from Scotty is that there's not enough room for a decent turbo. Just look at the size of those boxes and still some room to spare.....
can I come over and play!!!!!!
sorry scottiluvff.gifI have a new friend!!!
Edited by Jetwreck
There is just enough room for a TO4e compressor housing, or a GT30 4 inch. It will be tight but the Tial turbine housing will help fit it all in. Thats a decent size isnt it? :)
Remember most of that kit wont fit, like the intercooler and a majority of the piping. Engine out most probably to fit the manifolds and rear exhaust crossover although it may be possible if you strip the plenum right down, not a job I would like to try though. Lots of skin off the knuckles coming up buddy, have fun. I love the pain. lol. :thumbsup:
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
