people feel that they're fiddly things, when adjusting gains and etc.
but everything that comes out of japan is fiddly. lol people should deal with it.
Yeah mostly I think it is people not reading the manual and/or taking the time to set them up properly. It's not quite as simple as "I WANT 20psi, K.. GO!"
Also, some think they can't handle huge boost and prefer to go for the Blitz dual solenoid units. The theory there is that the dual solenoids can handle fast ramping, huge boost setups better.
Got it thumbsup.gif I dont see either of those issues being of particular concern to me - but good to know! cheers.gif
Defiantly are not plug and play.....took about half an hour of run's to set it up in Andy's car yesterday!...mainly because it takes so long to get to 60km/h :P
Edited by Jetwreck
thats normal though, like bubba said, you cant just input 20psi n say go. 30minutes is actually pretty good.
Did the RDA slotted rotors and EBC pads (red at the front, green at the rear) tonight; and a full bleed of the brakes. Waaaaaaaaaay more bite. Good upgrade, very straight forward :thumbsup: and, no brake squeal! :worship:
I did the same thing 2 months ago on my r32 GTR callipers, those RDA slotted rotors are great, no warp at all when you heat them up. I used the QFM A1rm's and they bite well, better than my EBC reds. Once they are hot though, my god they pull up! Better than any brakes I have felt before.
+1 for the QFM A1RM's
I wasn't really a fan of the EBC's as when I bought a set they would dust something shocking, and this dust would EAT the wheels! Pads were pretty good. Pretty average when cold though!
Dunc, just make sure you change your fluid to something with a slightly higher boiling point. The increase efficiency of the pads at operating temperature means you are bouncing up closer to the boiling point of standard brake fluids, giving your nice new pads a squishy pedal!
We bled them and put in a mid range PBR fluid; nothing too extravegant but better than what you'd get if you took it to a generic mechanic. I had the 'faded brakes' convo with my mate whilst we were doing the brakes, he felt pretty comfortable that what we were doing would be fine thumbsup.gif.
Even when cold, the new setup felt like it had a heap more stopping power than what I was driving this time yesterday - but given I changed so many components at once I wouldnt be so bold as to attribute it to 1 particular bit; as a whole - the system is working nicely. I'll keep an eye out for that brake dust though pirate.gif
The dreaded cold start ethanol issues? You may just need more fuel at cold start, do you have the Emanage software working yet? See if the temp sensor is hooked up to it mate. Not hard to fiddle with it...
Why is yours clogged? What's the symptoms?
I'm having cranking issues in the morning. Do I need extra volts to the fuel pump? New filter?
nah no problems for me.. just wanna get one so after the 2nd tank of ethanol i can change the filter, it cleans the tank..
well we all were having cranking issues and popping on Idle.
get some air flow meter cleaner, and clean the AFM.
Fixed my problem instantly.
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
