Done.
LOL...I don't mind...I just dont think they'll be as good value as a set of BC's!
I'm just worried that the front bar won't last long when lowered...look at the last pic! I won't be able to get away with that anymore!
You're right; BC's are the biz. Sorry Iain :nyaanyaa: It'll look solid with a bit of low.
Don't worry about the front bar; thats why touch up paint was invented...
i like a VERY firm ride, and the nismos arent stiff enough for my liking.
So if you like your ride so firm, what setting are you running on?
I think I saw where you changed yours from setting 3 to softest setting.. Is that right? If so, that makes the BC's a pretty firm coil over IMO.
At the risk of being too far off topic, I'm wanting BC's to lower the car but don't want to impact ride too much. It will already be affected slightly with the swaybars that are coming soon.
Can anyone tell me how much ride "quality" is affected by shock valving & how much by spring rates?
I can get the BC's with lower spring rates but not shock rates / valving.
It was actually me who wound the damping back to full soft. That was after I fitted the GB swaybars, as I'd been using the firmer damping to make the car more direct on turn in. After the bars it became like an apex seeking missile, so I was able to back it off and still have brilliant turn in, AND excellent ride. They have an extremely compliant ride. Iain runs his much firmer than I do, but I don't feel it's necessary.
i wound mine up further. im running about 9-10 in the front and 7-8 in the rear. i think im going to soften the front and stiffen the rear for some sideways bias.
front springs are 10kg/mm rears are 12kg/mm
one day ill go even firmer and see how that goes, but not on sydney roads lol
OK, thanks Dale.
Ride comfort is a very subjective thing. Your comfortable ride could be my kidney damaging, wife screaming future :blink:
I tend to think your ride probably is excellent, but I lack the confidence to just go & buy the BC's with standard spring rates.
It a little puzzling why most guys (maybe Iain excluded) run the damper settings pretty close to the soft end of the spectrum. You'd think that if BCR got their product right, the majority of M35 drivers would be on about the middle setting, with the Iain's of the world at the upper end and luxo lovers like me at 5 clicks from soft :/ .
I hate the idea driving at full soft and then having no where to go in that direction for those special occasions when comfort is most important.
Would 2 or so kg less in spring rates help or just bugger the handling?
to be honest they are real nice on the softest setting. not harsh but quite firm. nothing that even MY wife complained about. hence why its taken me 3 goes to get to the adjustment im at; mostly so she doesnt notice. now that it hurts her chest (like my old car) she is starting to complain lol
i dont think the spring rate would affect it much, that said, apparently scott has his BCs set around the middle of the setting, the damper settings may go even softer. but youll need to ask him, i think he has the 1100 model (cant remember the exact model sorry) however dale and myself both have the 1300 BC set.
ask craig about the nismos if youre interested in them, also stephen when he is back online as they came from his car.
Had a busy day on the Stagea today... Had 4 new Falken 912 tyres fitted today and a 4 wheel alignment. Think these will be better than my cheap RV tyres.. lol
Also made a little mod to the blow off valve to block off the small hole to improve boost response.
What did they find with the alignment? Any clue to that weird Tyre wear?
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
