nah factory wing, same as the one on Alex's PM35 and another one that was at the meet.
pic for you bigkev!
worth it purely because its my colour already
Edited by zei20l
lol it clips on, but there are 4 or 5 bolts underneath. youll need to remove the inside trim from inside the hinged glass tailgate section.
not a massive deal.
has your himount stop light died? mine too. i have a spare, but the non-wing models are different
Mine hasn't died- get back to me in 4 years time... then it will be as old as yours....:ph34r:
did you get a chance to check that diff out on the weekend? I know how far hassling you for parts will get me :P
nah i havent been there, but what am i checkout out on it? i thought you were coming to look at it?
I finished making the new fuel pump assembly today, all ready for the triple teflon braided lines. One Walbro HP and -6 line for each rail, it should just be able to max the injectors if I need it to. lol.
Hopefully the gtx turbo ships soon... :rant:
:worship: That looks like it'd set alarm bells off with ASIO :rofl: May have to get some details of your construction of this... eventually !
haahh thats some cool shit right there dude!!
not bad at all!! very clean
paint it black and no one will know its not factory.
how many PM35s do we have on here?
Cheers, yeh considering painting it black, or polish it a bit more.
I'm just not sure what to do with the breather line that usually goes back into the intake. Either make/buy a oil catch can or get a nipple welded on to it.
By the looks I need a new rubber joiner(from pipe to TB), it's starting to crack, so that'll be next!
just get a similar one like the blue silicone joiner you have.
then cut one side on a angle that suits the bend..or a bend silicone joiner
cutting the end is what I did and it works fine lol
make a nipple and put it back in if thats where its supposed to go. again, it will look factory and oil vapours will go back into the engine where they are supposed to lol
Not really. They go back in their because it was the easiest way from factory.
It's a proven advantage to vent them somewhere else. My RX7 has the breather go into a bottle... The optimal setup is a 2L+ bottle, with steel wool baffles and a drain back to your sump.
Oil vapour = lower octane of your fuel and grime up intake. Which we all know is an issue on VQ motors. When I ripped off my intake it looked like someone had poured a bottle of oil through the intake. (Given it probably had never been pulled off its whole life of 200,000km)
Yeh, i'll probably do that, or just get a silicone joiner the same as the black pipe, just a little more dollars.
Edited by JayM35
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
