You may find that once it it being controlled by the ecu, it actually pulls closed. Most throttle bodies have an air bypass port to control idle, and the butterfly seals completely.
Not this Throttle Body Dale. This one has no bypass.
This is why you have to clean them on a occasional basis or the car can start to stall.
Cheers
Andy
Cheers
Andy
Definitely explains the reason. A small amount of blockage would cause issues.
You learn something every day pinch.gif .
yeah spoolin has 19x9.5 +40 with a 12mm spacer so effectively a +28 offset... but they do stick out a bit - he has stretched tyres and they dont scrub.
but talk to him about tyre wear. with that width and offset you cant take out much of the camber or they will scrub the guards, so tyres wont last long.
Cheers mate, shot him through a PM.
I'm also looking to stretch so hopefully it won't rub too much.
Would a narrower rim help at all? The only reason I ask is the rims I'm looking at only come in +22, 10 or 0.
A narrower rim will always help. As I mentioned I am running 19x8.5 +22 and thats pretty flush.
You can work out how much more they will come out with the following equation:
(width (in inches) x 25.4(mm)) Divided / by 2 - the offset is how much rim comes out from the hub face
So mine that are flush are 8.5x45.5 = 215. Divided by 2 = 107.95. Minus the +22 offset = 85.95mm from the hub face. And thats about flush with the front guards: see pic below.
So 9.5 +22 would be 98.65mm from the guard. So it will stick out a further 12.7mm than what I have.
Ben.
Edited by bbenny
Ben.
That is a really good fitment...
Ben.
That looks perfect
I'm looking at something like this:
Yeah they would look awesome! Ce28 copy? are they Vaerrston or whatever the brand is called?
I should also mention if you run 9.5 you cannot run an offset higher than +35 or they will rub the front suspension arm.
Will look awesome!
I'm thinking of getting new wheels, I love my wheels but they're just a little too small. 18x9.5 at +15. I'll see how it looks once it's slammed with 25mm spacers.. So -10 lol
They are indeed.
So really my only option is the 9.5 to get a few tyre options and the highest offset these come in is +22 so rubbing on the suspension won't be an issue. I will do some ringing around RE 19in tyres to suit an 8.5 as if I can find some at a reasonable price I'll go that way.
They are indeed.
I think you said you were in Adelaide? Call Mark at SA Motorsport Tyres on 0409288380, tell him Ryan from Pure Motorsport sent you. He'll look after you.
Removed the Walbro fuel pump today and reinstalled the stock fuel pump and fixed my big hesitation problem around right hand corners ... :)
No issues supplying enough fuel with the stock pump?
It was well and truly maxed by 220, as the pressure dropped after that point and the injectors had to be opened exponentially to squeeze more flow out of it. Not where you want to be, fuel supply wise especially if you have stock injectors.
I may put the Walbro back in but need to do 2 things first,
1) use the filter fitted to the stock to the pump. (I think the filter fitted to the Walbro may be part of the problem. It is smaller and in less than 12 months has gone black)
2) Run the 12v power supply to the pump. I agree that the Walbro seems to perform better with the additional power.
Especially as I have the 60lb Siemans injectors to go in with the tune.
Went a bit overboard on eBay today, picked up my slimline fan ready for the front mount intercooler, and ended up getting a Nismo dash after putting in an offer... Bit sad, but ah well!
Do you have the factory Screen/Nav Unit. I saw the cluster on ebay also, but was trying to determine if it was the right cluster to suit car with factory screen (different part numbers according to Nismo catalog)?
I have a set of Nismo boost gauges. Looking for the Nismo cluster as we speak (ex Japan). Out of interest, what did you end out paying?
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
