Do you have the factory Screen/Nav Unit. I saw the cluster on ebay also, but was trying to determine if it was the right cluster to suit car with factory screen (different part numbers according to Nismo catalog)?
I have a set of Nismo boost gauges. Looking for the Nismo cluster as we speak (ex Japan). Out of interest, what did you end out paying?
Yeah I have the factory screen/nav. I thought they were only available for the cars with the factory screens?
Got it for $400 in the end, which I thought was pretty good considering the prices on Import Monster.
Nope...different units were/are available...
Iain installed one also:
http://www.m35stagea.info/forum/viewtopic.php?f=25&t=116
Good price though....
Edited by prince_skyline
Fingers crossed I have the right one then...
Can't look at that M35stagea.info link... seems down for me again for some reason... down about 70% of the time I go to look :(
yeah sorry about the site being down. its not, im back now so i can look into it!
all my info to the navi screen is missing. not that i care, its for tv and reverse camera. the dash looks the goods!
also note that that it DOES light up bright during the day, and at night it goes dimmer. opposite to the standard one. see if your hi-beam light is yellow. mine is. weird.
Yeah I checked http://www.downforeveryoneorjustme.com/ and it said it was up, but I'm behind a different ISP at the moment than usual, and still shows as down :(
Sounds like it'll work regardless then, but no more green leaf :( Ah well, fingers crossed I got the right one!
I had an issue with one of my sites previously with people behind TPG being unable to view. Ended up being a reverse DNS issue, might be worth looking into?
Plenty of different stuff available for 350Z/ G35 in the US (think Ichiba,etc), but going that way will actually REDUCE the wheel to guard clearance.
Maybe shoot spoolin12 a PM, I'm sure his offsets must be close to this after the fitment of his Akebono Brake setup, due to the required spacers to clear the calipers.
For anyone who is thinking about getting Ichiba stuff...
http://g35driver.com/forums/brakes-suspension/374310-ichiba-camber-arms-ftl.html
http://g35driver.com/forums/brakes-suspension/318174-ichiba-rear-camber-failed-please-look-check-yours.html
I'm assuming the links refer to damaged or weak parts, it was more of a general direction to that type of part, rather than a endorsement.
Good point nonetheless.
Yeah of course...didn't mean to insinuate you were endorsing them :thumbsup:
Just a warning nevertheless!
Cheers mate, shot him through a PM.
I'm also looking to stretch so hopefully it won't rub too much.
Would a narrower rim help at all? The only reason I ask is the rims I'm looking at only come in +22, 10 or 0.
Ill send you thru some photos when i get some off mine. i think i have +20 offset on a 18x10 inch rim with stretched tyres..
the rears are in just and the fronts are out of the guards by about an inch..
ok so my wing arrived while i was away, got it and put it on the car. finishes off the outside for me!
also installed regassed tailgate struts. now it opens and stays open lol
How much was the struts?
Might be time for a pic in the gallery?
Did you use "Strut Re-Gas" or similar? Cost?
$100 at my local mechanic.
yeah apparently they pressurize them in a box and force more gas in. the seals allow gas in, but not out (im sure they eventually leak)
anyway they work very well! now i have a spare set.
also have 2 spare working hi-mount stop lights work :)
Here's what I did to my Stagea on Thursday night on the way up the coast:
Tyre blew on the F3 just before the heavy vehicle checking station/weighbridge - luckily for me it just deflated really quickly instead of exploding. MASSIVE thanks to StageIan for helping, and then giving me a lift home from the coast.
Obviously I'll have to take a LOT of camber out when I get a new set installed in a few days - both sides were worn right down to the thread/metal...
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
