Well, after owning the stag for just over 4 years now and driving it pretty much as it came. I have almost completed my 1st couple of mods/additions.
I purchased a Turbo Tech MBC off ebay & after trolling thru a stack of threads I managed to get it fitted the way it should. I also bought a boost gauge & air/fuel gauge from one of the skyline boys, purchase a few bits & pieces from my local auto shop & fitted them below the radio in my centre console. StagMBC_2.jpgStagMBC_1.jpgStaggauges_1.jpg
Any suggestions on what I should put in the 3rd gauge slot???
Just fitted V spec Brembo all round , crap !!!! , is there a certain bleeding procedure ? , whiteline Anti roll bars front and rear , Awesome ! , front adjustable upper arm bushes , camber better ! ,
oil pressure
unplug the abs
bleed the rears, furthest from brake master (bmc)
bleed fronts (both sides of each calliper)
plug abs back in
Looks sweet once it's done eh?
Yep. I ended up putting on the darkest legal (30% i think?) as I got pulled over earlier that week and was told my rear windows were illegal. (factory stained glass from nissan) Haha.
^^ police are becoming stupider by the minute.
I had mine done 20%whistling.gifthey're almost exactly the same as the back. If it didn't look so cool, it'd be a pain in the arse...
I figure if I ever get pulled over I'm going with "it's all factory tint" If that doesn't fly, I'll just strip it , inspection, re tint. Mine only cost $100 for the pair.
I got me an oil pressure gauge, only thing is its too big for the slot. Was thinking of mounting it on the A pillar at a later date. Any other suggestions......maybe voltmeter?
BTW............forgot to mention that I made the plate for the gauges to sit in, dead easy.
IMO if you are going to run multiple gauges, the most important ones will be boost, oil pressure, oil temp and water temp.
Thanks, probably put water temp in the open slot in centre console. The oil pressure gauge is too big to mount under radio, so I'll look at making dual A pillar mount out of fibre glass for oil pressure & oil temp.
Just bought the 'power duct' through Nissan. Looking forward to saving that amount of money over the next 8years 5 months (HAHahahha) in fuel economy from sucking in hot air from the engine.... :rolleyes:
looking at connecting the fuel/air gauge 2d. pwr connected, just need to run sensor wire to the heated O2 senser on the ECU (pin 50) if I'm not mistaken.
Waste of time, unless you get a wideband sensor.
Oil pressure, oil temp, exhaust temp, accurate water temp and wideband are all critical if you are tuning imo.
OK then how fo you know if its wide band??? or not. The one I got is Autometer Pro Comp Ultra Lite (refer above pic). Shows - lean, stoich & rich.
A wideband wont run off the ecu, it requires a wideband o2 sensor to be placed in the dump. It will give you an actual value instead of just rich/lean.
This is the one I have...
http://www.innovatemotorsports.com/products/lc1.php
SHWEEEEEEET, something to save for asside from the home loan :D Thanks for the info, i also had a quick look at the new autometer clip for their wideband sensor/gauge.
Anyways, gonna finish wiring this up so my acr is ready for the trip to Dubbo 2m
got my intercooler today
ITS THE WRONG FKING ONE
sigh.. now have to way another 30 years for it to get here... and the fact that this "flood" has nothing to do with WA or where i am ordering my cooler from, it will still take bloody ages... so angry
well today i got the dump exhaust off..to fix the exhaust gasket leak.exhaust.. turns out there was maybe 1mm of the flange that WASNT leaking. When I pulled it off to fix it, it looks like the exhaust shop that did the exhaust did a dodgy, and shrunk the 3" to about 2.5" and put the stock flange back on (never taking it there again). Scotty the f**kn legend cut some of the exhaust off put it back to 3" with a new flange.. fixed.
Ok so made up a new gasket from Gasket material, with some gasket/exhaust seal. n put it back together..
it set.
Started the car.. i'de safely say about 50% of the turbo whine went away...sounds normal now..
still gonna take it to the turbo shop on monday to let him have a listen first..
once this all finished. i made some great souvlaki's and now im full and scotts so full he cant breathe!. goodnight Stagea owners.!
Edited by AaronNM35
that turbo whine you were hearing is awesome. LOVE the sound of the turbine when you have an exhaust leak :)
my bosses car has a dump straight to the ground from the turbo, i love driving it just to hear that sound. pity its attached to a mazda6 MPS
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
