mine were maxing before it cut.
so my informeter told me anyway.
so i was forced to baby the car around lol
emanage can clamp the aiflow at 4.6 as mine is.. anything after that is mapped by a boost sensor plugged into the emanage.
Yeah the Informeter suggests I max my injectors out without the suction.; hardly have to baby it - its first/second gear at 5k where I get into the upper region.
But yeah - mapping the extra airflow via boost sensor sounds fine to me. Its just clamping it at 4.6 WITHOUT the emanage that sounds like danger to me
So the suction pipe doesn't max the injectors just the AFM? If that's the case wouldn't a fuel cut defender fix that by clamping at say 4.6V? If the injectors are maxed then obviously needs bigger injectors.
If you're gonna cut fuel what's the point of flowing more air?
Am I missing something here?
I've got the MAP sensor installed but doesn't seem there's a need to use it...>_<
yeh it probably is a bigger danger doing it without bigger injectors.. which cant be done without an EMU
lol fuel cutdefender in this case would be used to clamp the voltage of AFM to 4.6v.. allowing it to rev freely without an air flow cut.
it adds fuel to the map if you have more boost.
ie. cold whether more boost - the map sensor will add fuel to keep it safe. get cihan to set it up
Ironpaw had a tune done before the map sensor was installed, so after 4.6 volts, cihan guessed the mapping, which he is really good at.
when he goes for the next tune, cihan will integrate it with the emanage
Whats wrong with your 3 dials? My boost gauge isn't working, but I found a thread on Scotty's soldering fix, so I'll do that, get it working, then think about changing it :D
mines an RX, only RS had the dials and the relevant sensors/loom etc. so if i cant get it working, ill be selling all the working bits and going a double DIN
the voltage readout works lol and i think if i change the BCM ill get the attesa working too. the boost sensor is missing the plug in the enging bay loom. but i rekon the wiring is there
i think there were tests done and raising the back of the bonnet doesnt really work. bonnet vents are the only real way to get air out :(
did you run a line from the battery directly to the pump? then its 14.4v already :P
Would creating a vent at back of the bonnet by timing the plastic trim on the back of the bonnet?
Cheers
Andy
Depends what else you do while raising it....trimmed some plastic out so it can flow/get dragged out.
I used a 12v relay...so it's 12v at the moment....If I need to step it up I will use the other one I got from Scott.
Did you want a factory boost sensor Iain or did you get one from the wreck?
Well that sounds like verdict is rip it off until I have done injectors, emanage and fuel pump? DAMMIT! And I was so looking forward to dyno day!
Wouldn't have thought a standard car with plenum spacer, exhaust and suction pipe would have maxed out the injectors?
I would leave it on until and see what the tuner can get out of it.....remember he will lean it off....you may get away with it running at about 92% duty cycle on standard boost!
I just spoke to Andrew, he was recommending a tune just with the exhaust. Sounds like I can do it without doing injectors etc, but excuse my ignorance can I get it tuned without going Emanage? I've only ever had one car tuned, and that was the R31 after I did the engine rebuild. Not exactly sophisticated so it was just done at Ultra Tune.
Unfortunately not on the stock ECU. Unless you send it to Japan.. :whistling:
Exhaust, Sierra S1 and stock boost you should get away with no injections with the E-Manage tune....or Exhaust, Suction Pipe, standard turbo and stock boost!....maybe!...anything more and you are pushing the envelope like I did!...not fun!
You will be in the 90% duty cycle mark more than likely.....so make sure your injectors are alway's clean!
Edited by Jetwreck
Yep. No tune for u unless u get an emu installed...or a fcon...
Lol at ultratune 'tuning' cars!!
Edited by ironpaw
Yeah agree, but it was just timing, nothing complex! Thats my excuse and I'm sticking to it!
Off to buy an Emanage then... any suggestions where?
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
