i was going to buy a new gt2831 or something but garrett gave me this turbo for free and i cost me 200 in gaskets and clamps and i am happy. i was doing 14.00sec quatermile before i did half the mods so now i am hoping for at least mid 13s in the end i want 12s then i will take it to a race track and see how it handles. but we dont get paid to work on our cars so the work gets done afterhours.
They were 300 cheaper then the br's though.
I found a guy on here that sells the BC racing BR's for $1165 delivered (http://www.streettotrack.com/). So your Silk Roads are still cheaper (but only by ~$165) and I'm not overly concerned about it being harder to adjust damping.
Can you tell me if they can be set up soft or do they start at "firm" & go harder from there, as per most Japanese coilovers? But with a name like "Silk Roads" they sound so soft & comfortable LOL.
The aftermarket ECU and tuning will be the biggest difference. If you search forced induction you will find a thread by rev210 on how to get 12's on a 33 with as much stock gear as possible. The stagea is a lot heavier.
Nice find Leon, good prices there. Just curious how you'd go with warranty though, could be a sticking point?
I believe he is an official reseller and has such handles warranty the same as the others. He is just keener for the business so does some forum marketing in his spare time. He is quick to respond to email questions, which is great, so maybe confirm with him. The only downside is the delivery time for our cars is about 15 days. From that I'd guess he doesn't keep ours in stock LOL. But I am a patient man so that doesn't bother me. I've been waiting on some spare parts since Christmas......
got suck down the coast at albian park rail with a dead battery on saturday. NRMA only had a smallish battery with the small terminals. hope it lasts!!
I think I have the small battery.... :(
that sucks. i might change mine to the spare if its still around
i had a pitworks battery in there, has been in there since japan! not bad, lasted over 2.5 years.
3.5 for mine so could not complain.... Only paid $80 for the new battery delivered to my car.
last time i went to the drags i had 6 runs of times between 14.00 and 14.10 it was pissing me off i just wanted to crack into the 13s i had shit tyres so i was changing tyre pressure to get grip off the line and i only had done intercooler, boost controller and pod filter and was getting 1.9sec 60ft so low 13s is no problems.
this is only the 2nd car ive ever repaced a battery in
Lucky bastard. I think I've replaced the battery in every car I've had *touch wood*
Mine is a Pitwork too, hoping it lives a long, happy, healthy life :cheers:
I was going to ask if your alarm issues could be related to battery issues :P
I was going to ask you if your handling issues could be related to stilts issues :P
Haven't checked actually, didn't even occur to me. Will look into it. Thanks :thumbsup:
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
