yeah where the oil filter adaptor bolts to the motor? has oil lines coming out of it to go to the turbo.
if water goes in there, i dont think its to cool the oil. the oil is generally cooler than water. maybe its to warm the oil up faster?
perhaps..
although the oil line for the turbo comes straight from the oil sump. lol
anyway i think the o-rings shit itself.
The water jacket heats the oil quickly up to operating temps, specifically the oil being pumped around the engine. It just means you can get on the gas quicker but is still takes twice the time generally to heat the oil. After this point its just backup cooling if the oil ever heats to over 90 degrees. There is a special orange oring behind the water block thats leaking on Aarons, he could have just siliconed it up but I suggested a new seal, mainly because I don't like silicone in the oil pathways if you can help it.
but its primary job is to heat the oil. and IF the oil overheats, then it will cool it. assuming your primary cooling system is doing its job well :P
ok you've lost me.. whats the primary cooling system??
the radiator and fan(s)
the oil lubricates the engine, but it does store heat too
Mmm, I think oil cools an engine more than most people think. I had a V8 when I was a lad that had a chronic overheating problem (one hard acceleration run would have it steaming) so I put an oil cooler on the engine. In winter I had to tape cardboard to the front otherwise the needle wouldn't move off cold & the heater wouldn't work lol. I reckon I could've run it without water, with just the oil cooler doing the job.
The proper term would be a heat exchanger just like the one in radiator for the auto trans fluid ...which also serves to bring the auto trans up to operating temp more quickly but also has some cooling function if the auto trans fluid gets too hot.
Finally removed the standard intake today. Bottom nut caused me all sorts of grief (typical for me unfortunately) by getting all round. Had to grind a slot in it using a Dremel with a flexible shaft to get up in there. A good hit with a hammer & screwdriver had it off in the end. I think I've spent more money on buying tools to remove the nut then I have on the materials to build the entire intake lol.
Its a pain in the arse to get up under there. Did you snap the stud off in the end?
No, the stud is intact & undamaged. Probably more from good luck than a well implemented plan LOL. I just ground a slot/vee most of the way through one face. The hammer/screwdriver combo spread the nut enough to loosen it & it came off without the use of tools.
However, the sexy & well engineered funnel & flange you made for me looks like it is too long to get any sort of bend before hitting the cross member. I'm going to hunt for some tighter bends (silicon & aluminium) tomorrow & have a rethink. I may have to make up something closer to what you've been doing all along.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
