Ok I'm a bit of a newby to turbos and was wondering if we had 3 prepped RB25's and bolted the same HKS 3040 turbo to each motor but had say a .6, .8 and a 1.0 rear on each turbo
what would the difference be on each power wise ie low down, mid range and top end which ar would give you the best average power?
what would the gains/losses be?
would this govern how much boost each turbo is capable of being efficient at?
If each turbo is say rated at 550hp how is this possible with 3 different rears or does this not effect the over all power?
https://www.sau.com.au/forums/topic/34863-rear-exhaust-housing-ar-sizes/
Smaller turbine housing - boost will come in earlier, but the downside is they wont have the top end of a larger housing - due to the additional back pressure. Also, with a smaller housing, it is more difficult to control how the boost hits, its either on or off - the net result of this is you would have to turn your boost down to drive on the street safely, and prevent unplanned lane changing.
The boost pressure where a turbo is efficient is dictated by the compressor.
Buggered if I know how a turbo can be rated at 550hp with 3 different rears, unless they rate at the smallest sized housing - which means the larger ones have the potential to make more.
Real world example, I had a 0.61 housing on 3037, boost came in so hard, at around 3000rpm, that the back end would step out at light throttle even in 4th gear and doing around 100kph. Not so bad if you want it to, but not so good in traffic. I am not sure about top end, but the turbo did make 256rwkw at 1 bar with an quick tune.
same turbo with 0.87, 1.2 bar (17.4lbs) at just under 4000rpm. The car pulls pretty hard from around 3500-3700, so around 500 or so rpm more lag (after changing to a higher flowing exhaust). I have 22lbs set all day, and can control the boost with the accellerator pedal. turbo now makes around 285 at 17lbs and 321 at 22lbs (around 1.6bar).
I much prefer the 0.87 housing. Much more lag though would be a bit too much IMHO. If you want my recommendation for a 3040, I would say go the 0.87. Merli had a 3040 with 0.87 turbine AR on his R33, it would be worth asking him what he thinks too.
Steve
would i gain any peformance/power from having the exhaust housing bored out on the factroy turbo
for the cost of taking it out getting the work done and then putting in back on, u might as well throw it in the bin while its off and get a decent turbo :D
BTW i got a 0.82 rear housing on my 3040 and its easy to drive in traffic and then when u go past 4000rpm its really fun to drive.
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
    • interesting....sounds like the later trans has software differences (or AM vs JDM). If I wasn't going down the tuning route it would be worth looking into retrofitting a new computer to the old box.
