you'd want to tap into the sump wouldnt you?
because there wouldnt be any oil in the pump until the car is cranked/running?
but it would suck from the same place (oil pick up) and put back in the pressure side to go to the oil filter . it wouldn't be able to suck thro the standard oil pump because of the gears ?
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5604820
whats the point of doing it. its not like engines have ever had an issue with starting on a normal oil pump before.
more for the fact that if your standard pump shit it self you have some chance of saving the motor
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5604965
yeah ok fair point, im not sure that you would have enough power in the electric pump to supply the oil
yeah im with this, if you need something large to get the oil round in the first place, i dont think a small 12v pump would help much,
be better off with a good oil pump (nitto or jap brands), or external wet setup.
Would be better off to use a pressure switch for an engine cut, by time the small pump kicks in the damage would be done
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5605205
http://www.turbowerx.com/Scavenge_Pumps/Exa-Pump/Exa-Pump.html
check this pump out
they reakon it can pump 100 psi and comes with a 2 year warranty
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5605514
For the money you'd spend on the pump, modifications, hoses, and fittings, you may as well have bought a jun/nitto pump anyway. Engine alarms and kill switches are the go to prevent engine death in the event of oil pressure loss, or accumulators if you want to protect against oil pressure surge as well.
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5605551
yeah, just buy a decent pump and a warning, in a built engine with crankcollar, and nitto/jap pump they can handle 9000rpm+ launchs without breaking.
seems more of a waste of effort and money to do it with a standard pump.
get the accumulator, but like mentioned in the other thread and on the site, those setups are for big hp and serious race cars
Edited by jangles
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5606157
I wouldn't bother farting around with the oil pump... If you wanted to add an electric pump, you would install it as a redundant/seperate system.... with it's own oil pick up, filter and feed into the oil galleries.
I'm just going to use the largest accumulator or 'accusump' I can fit, along with a good oil pump and oil pump drive.
J.
https://www.sau.com.au/forums/topic/348646-rb26-oil-pump/#findComment-5607051
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
