Rb26 Oil Pump
32gtrsteve
 Share
you'd want to tap into the sump wouldnt you?
because there wouldnt be any oil in the pump until the car is cranked/running?
but it would suck from the same place (oil pick up) and put back in the pressure side to go to the oil filter . it wouldn't be able to suck thro the standard oil pump because of the gears ?
whats the point of doing it. its not like engines have ever had an issue with starting on a normal oil pump before.
more for the fact that if your standard pump shit it self you have some chance of saving the motor
yeah ok fair point, im not sure that you would have enough power in the electric pump to supply the oil
yeah im with this, if you need something large to get the oil round in the first place, i dont think a small 12v pump would help much,
be better off with a good oil pump (nitto or jap brands), or external wet setup.
Would be better off to use a pressure switch for an engine cut, by time the small pump kicks in the damage would be done
thats what i was thinking, because of the position they may be in
For the money you'd spend on the pump, modifications, hoses, and fittings, you may as well have bought a jun/nitto pump anyway. Engine alarms and kill switches are the go to prevent engine death in the event of oil pressure loss, or accumulators if you want to protect against oil pressure surge as well.
yeah, just buy a decent pump and a warning, in a built engine with crankcollar, and nitto/jap pump they can handle 9000rpm+ launchs without breaking.
seems more of a waste of effort and money to do it with a standard pump.
get the accumulator, but like mentioned in the other thread and on the site, those setups are for big hp and serious race cars
Edited by jangles
I wouldn't bother farting around with the oil pump... If you wanted to add an electric pump, you would install it as a redundant/seperate system.... with it's own oil pick up, filter and feed into the oil galleries.
I'm just going to use the largest accumulator or 'accusump' I can fit, along with a good oil pump and oil pump drive.
J.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
