would a NA 33 have any chance at beating say a t32?
i am thinking about adding a turbo to my 33 - i know it's a big job but what i am getting:
Kings Super Lows @ front end
POD filter
2.5" Cat Back
other than the above cars stock except for rims...
i aint realy driven it hard yet, just don't know if it's 'fast' or if it's a slow POS
anyone with a 33 NA who would like to post some times - such as 0-100, or just perhaps top end speeds, or accelerations etc...
just need somehting to compare to....seriously thinking about doing some major work :D
or might even be easier to buy a half cut rb25det?
thanks guys
https://www.sau.com.au/forums/topic/34865-r33-na-tubo-should-i/
225 top speed with stock dif, 240 with turbo dif, 5.4 0-100 with gas, something miserable 0-100 without. 15.8 second quarter without gas, with extractors s-afc ii panel filter with cold air. and look below for my quarter time with gas.
nice - i'd rather get turbo than gas..
i couldn't get a large enough shot in stocko engine to make any major performance boost would i without changing the shit i would need to change when putting a tubo in anyway?
also - is the rb25det practicaly the same as the de? would i be able to just pull one and and other in, than new ECU? or would drivetrain etc need to be changed?
the engines are not really the same, different internals and the rest, cheaper to do the whole conversion.
Sorry but whats this? you couldnt get a big enough shot of gas into a stocko engine for noticable performance gains?? even a 55hp shot which is very safe on a stock engine will give you a big kick in the arse and see your skyline down the quarter in probably a low 15 to high 14, if you can drive the thing. tell me thats not a gain.
man if u can get a det half cut for that much ill buy it off you tomorrow for 200bucks more so u make a profit, most of the 1/2 cuts go for like 3g's plus, and if u know someone u might be able to get it down to 2500 or a little under gas it the cheaper and faster way to go. Whack on some extractors on for 200bucks and ill pm u about my airbox mod and u have the same car as mine beating stock turbos.
well, i was wondering the costs of refilling bottles etc - might be beter in long run to spend a few g's
but send me a PM with your airbox mod and what extractors you have - as i want to get some :D
right now i've only got a POD on it - rest is stock, getting it lowered at front monday and next week 2.5" cat back
yeah, i paid 16k for my NA 33, realy good condition car...
so if i add new rb25det that'l bring it up to 19 + labour to put it in...perhaps drivetrain changes also - all seems not worth it :)
i am considering a zex kit right now - wet shot and ill run it at about 70hp i think, any idea's how many shots per tank?
youll also need brake upgrade, ecu change, different clutch maybe? it will cost more than 3k to do an engine swap and the resale value wont be as much. you'd be better off selling your N/a and buying a stock gtst
while nos is fun, i dont see the main benefit, yes you can hit a button and have an extra 50hp instantly, but how often do you use that? i use my turbo non stop when ever im driving, constant power throughput, anytime i go past +0 mmhg im using its efficency
to go past +0 mmhg takes like 1 second of accerelation and i can keep doing it over and over, thats the beauty of a turbo charger vs nos
much more practical and cost vs benefit = a lot
vs nos using say 10 times per bottle or whatever?
im not playing anti turbo anti change stuff cos i can im just saying cost vs benefits and overall result
you may find to convert your gts to turbo charged will cost 4k extra, so the car cost 16k + 4k total, you now have a 20k r33 gts with a turbo on it, you wont be able to sell it for the same price as a gtst as its not a gtst, its a gts with a turbo
much like an r33 gtst with an rb26dett, no where the same value as a gtr
once you factor in all the shit involved, its probably better to sell the gtst and just buy a gtr
Gatty,
You're definately better off selling your car and buying a turbo model instead - if you're after more power.
I justified doing the swap on mine (to the RB25DET) because I like the R32 and it never came out with the RB25DET... Here are some rough figures on what it has cost me to do the conversion:
$4000 - 5 stud conversion with GTSt Type M brakes, R200 LSD, and 17" Wheels
$4000 - Series 2 RB25DET engine/ ecu swap, CES twin dump pipe, Apexi Pod filter, R34 GTt intercooler, and turbo timer.
Both the figures above included labour...
$8000 is a fair amount of money to make your car the equal to a R33 GTSt, as you can probably work out - selling (or trading) the car is the smartest option. Putting NOS on you car is also silly, considering it's illegal to drive on the streets with it hooked up, and in time it will wear out you engine.
Ryno
yeah ryno has a good point regarding an r32 with an rb25det instead of the rb20
but even taking away the fact that nos may wear out your engine (not sure if it does) but you wont get as much benefit from it, granted it gives u a nice 50hp or more kick when u hit the button but how often would u use it on the streets? i use my turbo on the streets all the time, on the way to work, the shops etc... its an all-round performer vs once every now and then with nos
Hey all,
im not saying nitrous may be better then a turbo, trust me if circumstances permitted i would have a turbo in 5 seconds flat. Merely expressing my oppinion nitrous being a good value for money alternative. Yes it is illegal in most instances but so are alot of mods that people do to there cars. It really depends what you want out of it i suppose. But to be quite honest i love it, its great fun for the occasional squirt and for when your not in the mood for driving fast the bottle isnt in ur car and u have the fuel economy of an NA car. Dunno just my thoughts.
Mate i havent had it long enough to tell you of ne long term effects, but the car is still as reliable as it used to be, and so far has given me no troubles. The internals are very different from what ive been told i havent ever actually seen the internals of the NA engine to compare it with a turbo, but ive been told they wont handle boost above 6-7psi without dramas. My car is a daily driver and has the bottle in for special ocaisions, never for just cruising around unless im in the mood and want to go somewhere appropriate.
yeah there are large differences between the rb25de and rb25det, other than just the turbo charger on it. compression is one thing. as N/A r33 said you wouldnt be able to run more than 6-7psi safely the engine will go bang due to compression. I believe the rods, pistons cams and other stuff are different too
yeah beating someone and saying you run 0psi is cool but beating some over and over on the same strech of road and running your stock turbo is better, whereas you are limited and its a costly limit too with nos
turbocharger is free power and doesnt need refilling, yes it comes down to personal preference, id much rather prefer the turbocharger
if me and N/a r33 went against each other, we would beat me the first time and maybe the second, once he runs out of nos its all over for him, and its probably cost him a good $200 or so? no idea how much a bottle of nos is. whereas its cost me $0 and i can remotely keep up pretty well if not run equal every run and when he's out of nitrous he'll have no hope of keeping up
give and take :(
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
    • Just buy a bunch of covers off aliexpress, they're like $5 each. Rattle-can them and stick them on as needed/fly off.
