Left overs from a R33 gtr vspec 1995 model
Complete body harness, from the fuse box to the tail lights - $150
Front strut brace - $ 100
Drivers side window - $30
Battery tray with fuses and relays - $30
Carpet good nick - $50
Heater box - $50
Door cards, ones a bit average - $40
Centre console - $30
Dash fascia - $40
Cluster surround - $20
Steering wheel and air bag - $100
Steering column - $30
Rear trims - $20
4 seat belts, Aus ones $200
ABS ecu - $50
Attesa ecu - $50
Bare rear cradle - $100
Active LSD - $800
Kick panels - $20
Door scuff trims - $20
Centre guages - $120
Hks boost controller with scramble function and button - $100
Radiator - $50
Ac rad and dryer - $50
One front and One rear standard shock - $20
Front sway bar - $40
Rear sway bar - $40
Climate controller - $40
Headlight stalk - $30
Wiper stalk - $30
Column surround - $20
Gear stick boot and surround - $50
Rear cradle bracing - $150
Rear floor bracing - $100
320kmh cluster - $400
4" cat back with cannon, dent in cannon - $300
Vspec Attesa pump, damaged - $100
Boot false floor - $20
Boot carpet - $20
3 Gtr wheels, one with a brand new 245/40/17 venturas, other 2 have average tires - $700
Ac rad fan, metal shroud - $30
Other shit
R31 3" cat back straight pipe under the diff - $250
C34 stagea Tein coil overs for 4wd manual, rs260, not base height - $250
RB20 complete with loom and stock turbo - $650
VG30 turbo and 3' split turbo dump, not all the way to cat - $300
Ca front brakes, hubs, knuckle, lcas - $250
More shit to add when I remember it...
Really would like pick up only, but will post at your expense.
Gawler SA, PM or get me on 0437 301 311.
Is it possible to put the Active LSD on a 33 gts-t?
Are the door scuff trims metal?
Any GTR seats?
Thanks,
Shannon
Sent PM as well.
Edited by Shazza24
GTRPSI, Will take pics and look for part numbers on the boost controller to day when I go there.
Shazza24, replied to your pm.
Ducati02, replied to your txt.
RBJETT, I have the passengers side drive shalf and hub. Nothing for the drivers side.
  • 1 year later...
